Old 05-31-2012, 03:33 PM
1534dover 1534dover is offline
96 LaSabre Flasher doesn't flash
My 96 LaSabre directional signals won't flash. However, the hazard lights do. Are there two flashers on this model, or only one? JiffyLube tried different light bulbs but that didn't work.
Is it necessary to replace the steering column directional signal switch? Help!
Old 05-31-2012, 05:29 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 96 LaSabre Flasher doesn't flash
Yes, there are two flashers. The hazard flasher is mounted on/near the steering column, you should be able to hear it and feel it to find it. The turn signal flasher attatched to the sound insulator panel under the left side dash. Should be a little round aluminum/tin looking piece.
Old 06-18-2012, 07:00 PM
Thanks for your information. I took the car in and my mechanic put in an extra loud flasher for about $20.00
Where is the flasher module on a 1999 Lasabre rdefino LeSabre 4 01-09-2009 01:34 PM
1992 lasabre flasher 87cutlass LeSabre 4 06-22-2008 07:56 PM
1997 LaSabre radio doesn't work after battery disconnected - not anti theft problem. A. J. Clark LeSabre 5 11-30-2005 09:48 PM
Why my hazard warning flasher doesn't work? stella88 Vision 1 09-08-2005 01:40 AM
93 lasabre no spark and with infl reset flashing dupre LeSabre 1 08-21-2005 03:40 PM
