Old 01-08-2009, 04:43 PM
rdefino rdefino is offline
Where is the flasher module on a 1999 Lasabre
I have a 99 lasabre. The passenger blinker work, but the drivers side doesn't. The was a burned out bulb on the drivers side, but I replaced it. I'm wondering if it's the flasher module. Any idea where it is?
Thanks
Old 01-08-2009, 05:19 PM
mgty3whlr mgty3whlr is offline
Re: Where is the flasher moduale on a 1999 Lasabre
It is a possibility that you may have a bad turn signal switch.
Old 01-08-2009, 06:15 PM
I thought that too. Whan you say switch, you mean the arm on the steering wheel..right?
Old 01-08-2009, 06:45 PM
yup
Old 01-09-2009, 12:34 PM
imidazol97 imidazol97 is offline
AF -Advisor
Thanks
If one side is blinking correctly, it's not the flasher which is the problem.
Turn on the 4-way emergency flasher and check all the bulbs from side to side. Check the little running light bulbs that are toward the sides of the front and the back. They should be blinking on and off with the turn signals.
Somewhere you have a bulb not making contact or not good. You can just start replacing the bulbs on the side that's not working. Keep the old ones for future replacements.
