Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-05-2007, 09:38 PM
87cutlass 87cutlass is offline
Send a message via Yahoo to 87cutlass
1992 lasabre flasher
Why will my turn signals not flash where can I find the flasher. I found the hazzard flasher and all of the lights are working when I use the turn signal they just do not flash.
Please advise
Old 10-07-2007, 08:51 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1992 lasabre flasher
The turn signal flasher should be located in the area at the left side of the steering column up in the dash. So look some more and you should see it. The hazard flasher to the right of the steering column.
Timeslip 08/12/06
AF Community Guidelines
Old 10-09-2007, 02:14 PM
spinne1 spinne1 is offline
It is behind the dash as BNaylor said. It is not super easy to reach. Basically you need to get a good flashlight and a screwdriver and lay on your back looking up under the dash with your feet over the top of the driver's seat. Look to your right near the wall of the car nearest the driver's door and then up into the space behind the dash. Do you see a metal round thing? That is your flasher. You need to pop it out of it's holder, which consists of two pieces of metal. Pop it towards the rear of the car and it should pop out. Once out, reach your hand up and work it down as far as it will go and then remove the wiring harness. Once removed, leave the wiring harness down low. After you replace the flasher simply push the flasher back up and flip it over some loose wires--there is no need to put it back in it's holder and besides it is very difficult to do so.
Old 06-22-2008, 06:43 PM
mikeab0 mikeab0 is offline
Smile Re: 1992 lasabre flasher
thank you for the info the screw driver and feet over the seat worked your the man!!!!!!!!!!!!!!!! thanks again mike
Old 06-22-2008, 06:56 PM
BNaylor's Avatar
Thanks for contributing to the forum.
However, this is an old thread so it has been closed from any further posting. See our guidelines below.
Old Thread Guidelines
Timeslip 08/12/06
Closed Thread
