Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 05-30-2012, 07:29 PM
mishalah's Avatar
mishalah mishalah is offline
power window switch
My front passenger window switch seems to have died. Where is the easiest/cheapest place to get one right away?
1996 1500LT, window works fine when I use the driver door switches.
2004 Yukon XL Denali Luxo-barge for towing. 6.0L AWD grandpa hauler
2005 Suburban 1500LT/awd/tow/everything else...soccermom cruiser
2008 Nissan Versa HB...wife's skateboard
1997 Jaguar XK8 convertible...best road car ever
1966 Mustang GT convertible...fully restored concourse show car
Old 05-30-2012, 10:02 PM
Blue Bowtie's Avatar
Registered Offender
Re: power window switch
It could be the passenger door switch, or it could be the feed through contacts on the master (driver side) switch. Diagnose completely before throwing parts at it. Been there with the POS imported Alps switches. Note the pitting, carbon, and corrosion:
Old 05-31-2012, 01:40 AM
mishalah's Avatar
I pulled the unit out of the panel to see if the contacts were dirty, but they seemed fine. The door lock switch would lock the door but wouldn't unlock it. I'm guessing the unit is worn out but tomorrow I'm going to try shorting across the window switch or window harness leads to see if it activates.
I wonder if I can pull a switch from the rear window and plug it into the front harness connector to see if that works???
Old 06-02-2012, 04:48 PM
mishalah's Avatar
Got a new one at AZ for about $35...minus all my discounts . Installed, works fine.
Oh....if you ever do this R&R, before you try the switch be sure the window lock button on the driver door is set so you can actually work the other windows.
Don't ask me how I know that......duh. :P
Old 06-02-2012, 07:46 PM
DeltaP DeltaP is offline
Ha,Ha!
Old 06-14-2012, 07:24 PM
mishalah's Avatar
I know. I know......sigh.
Worse, though, I sold the Sub and really miss it.
So, I'll keep drivin' this sissy 2005 until I can find a nice Sub with a bigger engine to pull a trailer. A simple broken light switch would be a blessing on this over-optioned girly cruiser. Just had the front differential rebuilt: nice and quiet, but I sure could have used the cash for something better.
Power Windows don't work joenobodyyet '96-'00 Civic 2 03-29-2012 07:07 PM
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
Broken Power Window Switch MitsubiGal Galant 0 03-29-2010 09:18 AM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 11:48 AM
