Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 05-27-2012, 10:05 PM
alleny87 alleny87 is offline
08 Impala 3.5L Trans Leak (First thread Dissapeared)
OK i got a 2008 Impala S 3.5L Flex Fuel and it just started leaking trans fluid from these two tubes that come from the front of the trans and turn up into it right in front of the trans pan, it also started kicking into gear when it warms up especially when moving from a stop. Does anybody know what these tubes are, have not had time to trace the lines, but noticed them wet after quick inspection under car, they ave what looks like a black rubber or hard plastic boot/grommet where they connect into. I'm fairly confident i can do the work my self but i don't have any idea of what the part to order would be called
Trans Service is up to date, done about 4 months ago, was expecting another service soon, but wasn't anticipating the leak, i believe they are the cooler lines, if so anybody know how much fluid i will loose
Thanks for any help
Old 05-28-2012, 09:09 AM
Tech II Tech II is offline
Re: 08 Impala 3.5L Trans Leak (First thread Dissapeared)
Those are your transmission cooling lines....they come out of the tranny and to the heat exchanger in your radiator.....
Older trannies had a nut coupling......the nut stayed on the line and you screwed it into the tranny to seal the line......the newer ones use quick connects......these just use a clip to hold the line in place......there is a round plastic covering to keep dirt out of the joint....all you do is rotate and pull and it slide down the tube....once that is off, give the line a good tug.....if it comes off, the line was not completely seated during your last tranny service.....if it doesn't come out, then the line is seated......
Rarely see these things leak....maybe dirt was on the line when the line was inserted, or possibly the seal was damaged during removal or installation, or the line was damaged, or maybe it just failed.....in either case, those fitting(s) in the tranny will have to be replaced.....
To remove the lines, once the collar is pulled off, a special tool goes on the line and you rotate it to spread the clip, and the line then pulls right out.....if the tool is not available, a pick can be used, but it takes some patience....once the lines are out , then the fittings have to be replaced, if the lines are seated and still leak....
Old 05-28-2012, 04:47 PM
Yeah i traced the lines this morning once i had some light to see. now i realize what they are i was hoping for just a replacement o-ring but not the case, thankfully the parts only like $30 dollars and if its the fitting itself then they are only another 4 bucks, i think i might just replace it all. Im pretty sure my buddy has the quick disconnect set i can borrow, if not i can use my pick set, i remember the tool from when i worked at a local oreillys auto parts, this job is simple compared to when my oil filter adapter gasket gave out, that thing is a pain to get to. But thanks for the help i do appreciate it
08 Impala 3.5L Trans Leak alleny87 Impala | Impala SS 0 05-27-2012 09:32 PM
92 grand caravan 3.3 Trans Leak Rschrei518 Caravan | Voyager 2 06-13-2008 01:35 PM
95 3.5l water leak mikeb55421 Concorde 1 09-03-2007 08:15 AM
2003 impala 3.4 oil leak beenpimpin Impala | Impala SS 3 12-19-2006 11:23 AM
Tags
impala , leak , transmission
