Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-17-2006, 01:45 AM
beenpimpin beenpimpin is offline
2003 impala 3.4 oil leak
2003 impala 3.4L?
i have a 2003 impala and it has a oil leak somewhere and i have to add a quart of oil every 4 days ...i also noticed that there is alot of gunk in the radiator and in the overflow resevoir but the car doesn't get hot at all....any suggestions on what might be the cause of these problems???
Old 12-17-2006, 06:12 AM
Pheezie Pheezie is offline
Re: 2003 impala 3.4 oil leak
I think its going to be your lower intake gasket. that was what was wrong with my 2000 impala 3.4 to fix plus a tune up costed me 621.94 . Mine started with a oil leak some where but never did see any oil on the ground. I had to put about a qt a month in for over a year. Had gunk in the radiator for about the same amount of time. 4 months ago I had to flush the radiator 3 times just to get all the gunk out. Then a month later the gunk was back and I had a leak of antifreeze coming from the back of the motor. Search these forums there is alot of info about intake gasket leaks it is very common problem for the 3.4 and 3.8 motors.
Old 12-17-2006, 09:47 PM
iwas told if I had a leak bad enough it was leaving a puddle on the ground that it couldn't be the lower intake..my leak is leaving a puddle on the ground...hmmmmmmmm...thanks for your advice
Old 12-19-2006, 11:23 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
There is an o-ring seal for the oil pump drive shaft that is a common oil leak on your engine. It is located in the center of the "v" of the block up top on the drivers side of the engine, and is basically a distributor with the top cut off. This o-ring hardens and causes oil to leak down the back of the block. It usually appears to be a rear main or oil pan leak as it drips to this area on the drivers side near where the engine and trans bolt together. The throttle body will have to be removed to gain access to change it. Fel-pro part # on the o-ring is 70800, and I also put a paper gasket #70194 as added insurance. You'll also need a throttle body gasket part# 60983 to finish the job.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
