Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 05-27-2012, 02:36 PM
timbrigham timbrigham is offline
Passenger side power window 2006 Stratus
I have a 2006 Stratus which the passenger side front window is not moving on. I pulled the door panel and hooked up a multimeter. I am getting 12 volts from the purple striped to yellow cable while the drivers side switch is disengaged. I am getting the same if I press up on the drivers side switch and nothing if switch is pressed down. My thinking is the problem is in the switch module on the drivers side during to the fact I'm not seeing a change in the up and neutral positions. Is this accurate? If not what should I look for?
Edit, power in upper tight and lower right corners.
Old 04-07-2013, 08:47 AM
spike1269 spike1269 is offline
Re: Passenger side power window 2006 Stratus
Do you know if it has the booster / module?? sounds and does it do the same thing with driver side plugged and or unplugged?? If you know what wires control the up and down of the power motor, I would try and bypass them with a direct line from battery to each and make sure the motor does indeed work..I think the driver side has to be plugged in to give the other switches power, or to complete the circuit. hope that helped. Also I think my book covers that car.. when I get some time to find the book Ill see if they have what it should be listed, and get back to you.
How do you replace the passenger side power window motor pint4 M Bodies 4 06-25-2007 07:03 PM
Caravan 2000-Passenger side power window. Bacoman Caravan | Voyager 3 08-08-2005 11:07 PM
Passenger Side Power Windows :[ AidenFox Grand Cherokee | Grand Cherokee SRT8 5 05-21-2005 06:21 AM
Passenger side power window motor replacement? Help!!! Cogtx Windstar 8 02-17-2005 11:55 PM
1999 Grand Cherokee problems with passenger side power windows, locks, mirror mklein Grand Cherokee | Grand Cherokee SRT8 9 07-03-2004 07:10 PM
