Old 05-21-2007, 01:53 AM
pint4 pint4 is offline
How do you replace the passenger side power window motor
On my 98 Chev Astro Van, my passenger side power window motor finally died. How do I replace it? What is the procedure-step by step is preferred.
Thanks.
Bob
Old 05-21-2007, 09:56 PM
old_master's Avatar
Advisor/Moderator
Re: How do you replace the passenger side power window motor
Remove the trim panel. The original motor is riveted in place. Drill the (3?) rivet heads with a 1/4" drill. Have an assistant hold the window from falling down in the tracks. Unplug the motor and install the new motor. Use 1/4" x 20 x 3/4" stainless steel bolts and stainless steel nylon insert nuts. Reinstall the trim panel. Total time: 45 minutes
Old 06-22-2007, 02:21 PM
herbal_gardens herbal_gardens is offline
Ive found that the nut and bolt kit that comes with the motor to be very teadious during installation so I replaced the nuts and bolts with self tapping screws and thred lock. Havent had any problems with it sence and its been over 4 years. ~Chris
Old 06-24-2007, 07:06 AM
CD Smalley CD Smalley is offline
I did it like this:
http://members.cox.net/notdadsw41/astro_window.htm
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 06-25-2007, 06:03 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
i'm really lazy, i just riveted the new one on too. watch for a rivet set on sale, they come in real handy. i use mine several times a year and they never come loose from vibration.
Originally Posted by CD Smalley
great tip and another great use for duct tape. you can get the glue residue off the paint and glass with Goof Off a paint and adhesive remover or my favorite, Zippo lighter fluid. but remmeber, the longer you wait the harder it will be to clean up.
