| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
foggy cement
i notice a lot of times after i glue pieces to the model (especially headlights or tail lights) that a white fog devolopes on the plasic after the cement dries, i think beacause the plastic has melted turning it white. anyways i was just wonderinghow to stop this for happening. your comments are appreciated
Krystal Clear glue for the clear pieces.. works wonders.
Re: foggy cement
Krystal Kleer, Elmers glue, Testors clear parts cement, these are the only things I can think to use with clear parts glueing. Regular plastic model cement and CA glue are not suitable for clear parts glueing.
Elmers works?? haha cool..
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes 1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials 2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater |
Elmers glue is the best for clear parts. :alien:
Re: Re: foggy cement
This stuff fogs? Hardly. It's even used to make aircraft windows. Just use it sparingly because it doesn't get tacky very quickly. |
I use tacky glue
Ryan If your new to the AF modeling forum please read this : AF modeling FAQ Current Project: Tamiya Porsche Boxster Special Edition |
Current Build.....1/12 Scale Camaro......Almost finished!!! ![]() ![]() View All My Models Here. |
If you are using CA/Superglue, it leaves a white residue as that is the glue vapour drying as it evaporates. Normal styrene cement glues by melting the plastic together.
To reiterate the others Kristal Klear/PVA woodglue is ideal for clear parts. It takes longer to dry, but is fairly tough when dry and also dries clear. If you made a mistake, it is easy to remove the part and start again. |
In case anyone is searching for it, I hope this picture helps
