Old 05-25-2012, 10:40 AM
glc4123 glc4123 is offline
1997 gp a/c problem
yes, i tried to refill a/c and the clutch won't start up, does any one know where the low pressure switch is located to jump the clutch? also if jumping what terminal do i apply the 12 volts to?
Old 05-26-2012, 09:25 AM
Tech II Tech II is offline
Re: 1997 gp a/c problem
Unfortunately, I think, this is not a CCOT system.......
Instead of a low pressure switch on the accumulator, this uses a 3 wire pressure sensor......you can't jump this harness to make it turn the compressor on(the voltage varies from 0-5 volts, depending on the pressure).....you try applying 12 volts to that harness and you may take out a PCM....
Not sure on this year model, but it's possible a code has been set(low pressure), causing the PCM to disable the compressor......if you have enough pressure in the system, you may have to clear the code first.....do you have gages to read the hi and lo sides?
Stalling problem as well as running problem 1997 Grand Caravan semperfi1977 Caravan | Voyager 10 05-07-2008 10:37 AM
1997 XJ6 Radio Problem drhayes XJ6| XJ8| XJ12 | XJR 4 04-18-2005 10:41 PM
1997 Galant Brake Problems LesPaul Galant 4 10-24-2004 10:20 AM
1997 GrandAm Electrical Problem lestat Grand AM 2 11-21-2003 05:34 PM
1997 v6 alternator problems bowtiebutch Grand AM 2 11-10-2003 03:39 PM
