Go Back   Automotive Forums Car Chat > Cars in General
Old 05-24-2012, 07:50 PM
dsorboen dsorboen is offline
Applying sealant and wax to a new paint job
Can anyone explain why you shouldn't apply sealant and wax to a new paint job? I was told to wait 6 months. Is that the normal timeframe?
I was hoping to have my vehicle in a showing this summer and I wanted to make it really POP.
Old 05-27-2012, 11:33 AM
jayrerickson jayrerickson is offline
Re: Applying sealant and wax to a new paint job
Its to make sure every thing is dry before you put wax on and seal it up. As for me, I use a buffer on new paint. Use a polish with the buffer to bring that shine out and it dries the paint better. Use a real buffer that will create heat. Heat is how you get that show finish. The buffer heats the clear coat just to its melting point. The clear coat then lays flatter and gives you that shine. At the same time it dries the new paint better. Thats how you get scratches out. The buffer heats the clear to the point where it is just about to burn melt and pushes clear into the scratch. Go here http://www.elite-custom-cars.com A lot of info on automotive paint with the supply's you need.
Old 05-27-2012, 03:27 PM
BIG E CUSTOMS BIG E CUSTOMS is offline
You do have to wait before you wax new paint. If your clear is not fully cured wax can cause the clear to cloud. Fast wax is the only wax you can use right away on fresh paint. It is designed for this purpose. Talk to your jobber.
Old 05-27-2012, 07:14 PM
Thanks for everyones help.
Old 05-30-2012, 01:21 AM
noman75 noman75 is offline
worth comment. I think that you must write much more on this topic, it may well not be a taboo subject but typically folks are not sufficient to speak on such topics. To the next. Cheers
Condos for sale in Mississauga
Old 05-30-2012, 02:06 AM
This is true but if you use a buffer with a polish or an extra fine compound you could wax it right after. The heat from the buffer cured the clear and gave it a better shine. Now you put wax on to protect it. Theres a lot of heat that comes from the buffer. Burn the paint right off if your not careful.
Best place for information for auto reviews.
EliteCustomCars
Old 06-04-2012, 03:37 PM
shadows shadows is offline
you never sanded down a vehicle, fixed a few spots, & painted it- when a customer was paying $700.00- $2,500.00 for quality and finish- did you
Old 06-06-2012, 09:22 PM
pontiacman428 pontiacman428 is offline
This is pretty much on the mark. Let me add I've always used "butter wax" which is a very light wax & smooth like butter with no carnauba added which allows it to wear off in a couple of weeks or so. This is good for the uncured urethane paints which takes 30-90 days to fully cure depending on the UV sun exposure. But as suggested talk to an autobody supply store.
Old 06-07-2012, 05:11 AM
Berldn's Avatar
Berldn Berldn is offline
Send a message via AIM to Berldn
yeah. but someone ask what is the time frame. it is obvious to wait after the new paint..
led lights
Old 06-07-2012, 04:34 PM
For lacquer 7 days should give it plenty of time to harden but if you know how to check it then it could be as little as 3-4 days.
http://carpaintcolors.org
waxing new paint rjogle Cars in General 1 01-03-2006 06:40 AM
want new paint job and tops what should i got with 95firebird Camaro Discussions 8 08-10-2005 09:38 PM
new paint job costs, experiences? fierce Prelude 0 12-21-2001 08:53 PM
New Paint Job... I think im fucked.. DCastillo Cosmetics 30 11-10-2001 03:06 PM
