Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 05-24-2012, 01:02 PM
snails snails is offline
help needed with 89 iroc
So I have a 1989 iroc z with a blown engine. I also have a 1999 gmc Yukon wrecked with a perfectly good 5.7 liter vortec. I'm just wondering if I can use the vortec motor without having to make modifications to it. Somebody please help. I need to get the camaro going ASAP.
Old 06-25-2012, 09:57 PM
chronomafia chronomafia is offline
Re: help needed with 89 iroc
I know that the blocks and all of that are the same and with the engine being a vortec you will be getting better air flow and all that due to the porting on the heads. The only thing that I can think that could be the issue is the distributor? The Iroc used a vacuum advance set up right?
Also, some of the sensors may be different as well as the motor mounts. Tranny will bolt right up no problem though. I would use everything thing that I can and just swap the intake and distributor from your old motor.
Help needed with headlights Piranha1187 Camry/Camry Hybrid/Vista 2 01-23-2004 03:12 AM
lil help needed with my subs BP2K2Max Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 10-23-2003 12:24 PM
Help needed with 1993 UK Maxima Cos Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 10-12-2003 10:21 PM
Help needed with wiring and electrical project... SilverY2KCivic Engineering/ Technical 28 05-07-2002 11:09 AM
Help needed with power cable install in accord AccordCE8 Car Audio 7 03-05-2002 06:54 AM
