Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 05-22-2012, 09:27 PM
mrappe mrappe is offline
1999 VW Jetta 2.0 has codes P0304 and P1582. What should I look at first to fix it ?
This is my sons car and with the check engine ligt on we can't get the state inspection renewed. I am trying to see if it is something that we can fix. In the last year we have replace the timing belt and put in a clutch kit and replaced the radiator fans. The car drives Ok but has a lumpy idle. once you give it some gas it revs just fine. I have a code reader and have erased the codes but they come back. The P0304 is Cylinder #4 misfire and the P1582 is Idle Adaptation at Limit
2000 Jetta 2.0 OBD2 Code (PO422 02 Sensor Question) Syberfinder '97 - '03 0 03-11-2011 12:40 AM
2001 2.0 Jetta with 5 codes???? moemo '97 - '03 1 12-29-2009 05:22 PM
need vacuum diagram:'88 ram d-50,mitsu 2.0 liter cukoobajube Ram Pickup | Ram SRT10 0 05-31-2009 05:59 AM
1999 Jetta 2.0 4-cyl: Poor power and acceleration, is this car a lemon? Dano2 Jetta/Vento/Bora 0 04-25-2006 01:34 PM
1999 jetta 2.0 cooling fan problem tyroneb '97 - '03 1 02-17-2005 07:51 PM
