Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 05-20-2012, 07:09 PM
garypr1 garypr1 is offline
2003 Impala LS w/6500 miles_popping noise in steering column
Just picked up a 2003 Impala LS with 6500 miles on it. Previous owner was 93 yr old lady who recently passed away. Car was always garaged and appears brand new. The only problem so far is that occasionally theres a popping noise that can be felt through the steering wheel. Ive felt it when turning, going over a speed bump, or rough pavement at low speed. I was told it could be a steering coupling that needs grease or replacement. Any comments regarding difficulity of repair, cost to have it done, or suggestions appreciated. Thanks, Gary
Old 05-20-2012, 08:19 PM
Tech II Tech II is offline
Re: 2003 Impala LS w/6500 miles_popping noise in steering column
Possible intermediate shaft.....should be a TSB on this....
Old 05-26-2012, 10:10 AM
raast raast is offline
If indeed that, some info...
http://impalahq.naioa.com/TSB/TSB01-02-32-001A.html
Old 05-26-2012, 12:04 PM
That TSB has been changed so many times, with different fixes.....
Old 05-26-2012, 02:20 PM
.. and none of them are particularly effective, lasting about a year or so. The "plug" was supposed to prevent lubricant loss.
It doesn't.
Old 05-26-2012, 05:43 PM
That plug is not left in the shaft....only used to disperse the grease, and then removed.....
First, you replaced the shaft......then next bulletin, you greased it....then another bulletin, you replaced it again, then greased it again....then a bulletin came out, depending on color of shaft, whether you replaced it or greased it.....crazy....
Different models had different fixes, also.....and different TSB's....
What Type Steering Column Do I Have? dave_in_az Grand AM 1 03-28-2012 05:06 PM
Loud creaking noise while turning??? wolfdog Engineering/ Technical 2 06-09-2011 01:46 PM
2003 Impala turn signals [email protected] Impala | Impala SS 4 08-14-2010 10:23 AM
Steering noise grandpax2 Century 1 06-28-2010 07:50 PM
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 12:57 PM
