Old 06-09-2011, 08:01 AM
wolfdog wolfdog is offline
Loud creaking noise while turning???
Please Help!!! My '96 Town and Country is making this loud creaking noise when turning (both ways) while in motion. I know nothing about cars and desperately need help... Any ideas???
Old 06-09-2011, 11:06 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Loud creaking noise while turning???
Lots of possibilities for that creaking noise - could be a wheel hub bearing , a defective drive axle ( unlubricated due to damage to CV joint rubber shield ) , a spring that is rubbing bare metal as it cycles , the engine cradle rubber mounts worn enough so it can move around when turning , and ...well , it's difficult to pinpoint a squeaking noise when you can't actually ( or literally ) see or hear the problem . Doubt this helps with your frustration over the issue ? Good luck !
" Sometimes I grow so tired "
Old 06-09-2011, 12:46 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Fords of that era have quite a common issue with dry outer tie rod ends and ball joints. To troubleshoot these, I use either a needle greaser with my grease gun or a pin pick through the boot and spray white lithium grease. I try to narrow down at least which side the noise is coming from and if it seems more like ball joint or tie rod end, then lube one at a time inside the boot. If the one I choose to lubricate makes no difference, then I move to another joint, etc. until I find the one that makes a change. From my experience, you'll notice a change VERY quickly. Also, the white lithium grease "fix" will only be a temporary one.
-Rod
Noises while turning Barudar Taurus | Taurus Wagon 6 12-05-2010 08:57 PM
Weird noise while turning CSanderson HHR 0 07-20-2010 09:17 PM
Creaking Sound while turning wheels...sounds like old, rusted door vwjetta96 Stratus 5 06-09-2009 12:59 PM
02 Creaking noise left turn almost non existant right turn or straight klvthatsme Envoy 4 08-19-2008 07:38 PM
Creaking noise when turning, accelerating, braking... Linger1974 Jimmy 1 11-25-2003 10:37 PM
Tags
creaking , noise , steering , turning
