Old 06-03-2003, 05:02 PM
Shlimplisket Shlimplisket is offline
1993 S-10 Problems
I just bought a 93 s-10 and when i took it for a test drive, everything worked, guages and all. Now, two days later, the speedometer doesnt work, the voltage guage goes way WAY up, the fuel guage changes randomly, and just today, it decided not to start. I ran the battery down trying to get it started. Does anybody know how i can fix some of these problems? Please help.
Old 06-11-2003, 08:49 PM
themodelkid's Avatar
themodelkid themodelkid is offline
Send a message via AIM to themodelkid
welll A. your speedo cable could have rotted out and broke, take a look at it, it connects to your tranny on the side, you should figur it out, B. you prolly do have a bad battery if you ran it down trying to start it, lol. C. I'm not too sure bout the volt meter or your gas gauge, you could have some screwy wires, i have never had that problem so i cant really help u there, but i hope those other sugestions help you out! Good luck!
themodelkid-Frank
2004 Dodge Intrepid SXT 3.5L HO
Brilliant Black Crystal Prl. Metallic
250hp, 250 lb ft tq.
1995 Dodge Intrepid 3.5L
Stone White
230 hp, 246 lb ft tq.
Supercharger in Works...
1987 Chevy S-10
Midnight Blue Prl. Metallic
300hp, 314 lb ft tq.
5.0L Baby...
Old 06-11-2003, 08:51 PM
..... or you (the worst) you could have a bad computer in your truck witch would cause all the problems except the speedo, but i dout it.
themodelkid-Frank
Stone White
1987 Chevy S-10
5.0L Baby...
Old 06-26-2003, 08:39 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
did any of your lights get brighter when the volt guage read high? if so, it could have been your voltage regulator. And with that kind of spike it could have damaged other stuff as well. I have never torn into the dash on a 93, but as far as your speedo goes, it may not have a speedo cable, some GM's use a VSS (vehicle speed sensor) on the side of the tranny to send signals to the ECM to calculate vehicle speed, and the voltage spike could have damaged it. Just guessin.
Old 06-26-2003, 09:23 PM
350 s-10 350 s-10 is offline
Send a message via AIM to 350 s-10
Talking i had close to the same problem
i got a 92 s-10 and the guages on mine like the temp guage when you start it up the needle shots right up to and so does the oil temp 80 and it stays there also the battery does 2 is it just a fuse or what is it
Old 07-10-2003, 06:04 AM
s10frameoff1993 s10frameoff1993 is offline
Send a message via AIM to s10frameoff1993
I have a 93 S-10 and the Vehicle Speed Sensor is plugged into the side of the transmission. there is no cable. Later.
-Chris
~CS4LIFE~
www.csautoclub.com
Frame off on a 93 S-10 Pickup
Bagged & Layin' Frame
Chassis Is Molded And Painted
Suspension in ENTIRELY Chromed
Engine is Painted & Chromed
Polished Fuel Cell & Braided Lines
Stainless Steel Braided Brake Lines
"The more chrome the better"
Old 11-08-2004, 10:15 AM
94S-10/4x4 94S-10/4x4 is offline
Re: 1993 S-10 Problems
I have a 94 s-10, does anyone know if it has an electric or cable speedo
Old 11-08-2004, 06:47 PM
STOVE BOLT STOVE BOLT is offline
-Chris
YEP.. CHRIS IS RIGHT. I HAVE A 93 S-10, AND IT HAS NO SPEEDO CABLE. IN MY OPINION, YOUR ECM WENT SOUTH.
Old 11-08-2004, 10:18 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
This has nothing to do with the no start condition.
Who cares about the dash working when the truck won't start up.
Have you:
Checked the battery?
Checked all the wires and cap and rotor?
Have you checked for a bad CPI injector in the upper plenum?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-09-2004, 09:02 AM
If The Speedo Is Gettin Kinda Funky, Or Has Quit, It Definatly Is The Computer. It Is An Electronic Speedometer. Nothing Else Controls It But, The Computer. Combined With The Other Problems, That He Explained, I`ll Bet The Ecm Is Bad.
Old 11-09-2004, 09:19 AM
Mikado14 Mikado14 is offline
Let's look at what the poster of this thread has said.
First- he says that the voltage on the voltmeter goes way, WAY up. Two things can cause this, A bad regulator or a bad battery. If the specific gravity of the battery is low, like 1100, that battery will act like a high resistance to the alternator and the voltage could go as high as 16 V. Seeing has it is a used vehicle, maybe the seller put a surface charge on the battery and it only lasted for 2 days. Have the battery checked.
This same problem could cause erratic operation of the fuel guage, the VSS or any other electrically operated device due to the fluctuating voltage. The ECM should more than be able to handle the fluctuations since the CPU in the ECM utilizes 5V TTL circuits and I believe 12V CMOS and there are internal regulators in the ECM to prevent overvoltage.
Check the battery!
Old 11-09-2004, 04:00 PM
BlazerLT's Avatar
AF -Advisor
Or, how about considering a bad digital dash as the overall problem.
Old 11-16-2004, 08:07 AM
1999bravada 1999bravada is offline
Re: Re: 1993 S-10 Problems
For 1993 you should have an electric vehicle speed sensor instead of a mechanical speedo cable.
Also if you have an automatic transmission, in 1993 GM started controlling the transmission shifts electronically.
Old 11-16-2004, 08:16 AM
This is not necessarily true, but most certainly a definite possibility... I have a 1993 G Van which has the same auto transmission as the s-10 series and a 4.3L engine, but no digital dash. The signal from the VSS goes to a vehicle speed sensor buffer box before it reaches the speedometer and ECM. The buffer is a little white box with a circuit board in it just under the dash on driver's side and it takes the signal from the VSS and changes it to tell the computer what size tires the vehicle came with from factory, etc to regulate the speedometer output. I'm assuming this should be true as well for a digital dash, but with his other problems this has to be something either in the dash or the ECM as you surmised.
Also, to the original poster, you may want to check your grounds in the dash.. my analog dash on 1999 Bravada cuts on and off sometimes due to a bad ground somewhere in the instrument cluster.
Old 01-05-2011, 07:34 PM
OtisvilleBill OtisvilleBill is offline
I was having the exact issues you were, and intermittently. I DID notice that it would happen after going over bumps, at times, so I concluded that something was grounding out/moving.
Long story short- my positive battery cable, going to the starter had made contact with the exhaust manifold, melted and the thing was grounding out at times.
It caused the dash lights to flicker, my gas gauge and speedo to act erratically, etc...
Check your wiring and save a lot of money.
Bill
1993 S-10 4.3L Starter Problem- ignition switch belewbaden S-10 5 05-25-2007 10:34 PM
1993 s-10 Blazer seat problems jut_man Problem Diagnosis 1 01-04-2007 06:26 PM
1993 S-10 Blazer PROBLEMS!!! Armista S-10 0 10-29-2005 06:50 PM
Common problems for a 1993 S-10 joblo33 S-10 12 02-28-2005 06:10 PM
1993 S-10 problem Monte8s7s Engineering/ Technical 1 05-30-2004 10:51 AM
