Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 05-12-2012, 01:41 PM
BrantDavis BrantDavis is offline
Question 85 jetta gl: clutch, linkages, or transmission?
I have a 1985 Jetta GL with the 1.8L engine, 5 speed manual. first off, recently, it started popping out of reverse before i even let off the clutch all the way. i tried holding it into reverse, but it jerks violently the entire time you're reversing. my brother in law says it might be the clutch, but wouldn't it do the same with all gears if it was the clutch? any help? also i have been having another problem. the other day it started ticking when the car was in motion, but not being pushed forward by the motor. (if i let off the gas, push the clutch, or take it out of gear) it's coming from either the axles or the transmission.. the boot on one of the cv axles isn't properly in place, but i'm not sure what exact thing would be making this noise. would it be bearings? i'm far from being a mechanic, so please give detailed explanation of what you think might be going on
Old 05-12-2012, 01:42 PM
Re: 85 jetta gl: clutch, linkages, or transmission?
I FORGOT TO ADD the ticking speed is directly proportionate to the speed of the car is moving. (the faster the car is going the faster it ticks)
2003 Forester transmission/clutch problem? JonnyU Forester 3 07-03-2011 03:49 PM
Clutch linkage parts Ragtop_Renegade Ram Pickup | Ram SRT10 1 08-02-2005 10:20 PM
clutch linkage pawnfirst S-10 1 04-17-2005 08:46 AM
Clutch linkage Jimmac Explorer | Explorer Sport Trac 0 01-05-2005 01:00 PM
GM A body clutch linkage question 4speedsupreme Engineering/ Technical 0 08-16-2004 09:22 PM
