Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 05-10-2012, 09:20 AM
Panoz Paul Panoz Paul is offline
Clutch Slave
Greetings .... I'm replacing my hydraulic clutch slave again; number 4 over the last few years ... Has anyone traveled this path & discovered a better solution ... I've installed the so-called up graded "O" ring after the second time , but ... Thanks for your insight(s) Paul Winship / Duluth , MN
Old 05-10-2012, 04:44 PM
DeltaP DeltaP is offline
Re: Clutch Slave
I do know that if one has the bad habit of resting their foot on the clutch pedal constantly it will keep pressure on the cylinder and short live it. Just sayin'.
Old 05-10-2012, 06:32 PM
panozracing's Avatar
panozracing panozracing is offline
Re: Clutch Slave
Throw that entire system in the trash! I have several new willwood slaves if you want spares. Go with a hydraulic throughout and a triple disc tilton or quartermaster that you can buy on ebay used from nascar guys.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 05-11-2012, 12:22 AM
boothkc boothkc is offline
Re: Clutch Slave
The external slave is unreliable and not suitable for use. As Brian said go with the hydraulic t/o bearing (ie slave and t/o are one unit inside the bell housing). This has been Panoz standard upgrade for several years. I think it is make by Quatermaster as well. We use the QM (8.5") spec clutch and t/o bearing. You can get from Panoz or QM (they will know the #).
It is pretty a pretty complicated PIA to get it set up right as clearance shimms require removal of the engine to re adjust.... so go through the directions and do it right the first or 4th time...
Kevin
GTS and GTRA for sale
997 Cup GT3
Old 05-12-2012, 11:56 AM
Re: Clutch Slave
I use a Mcloed hydraulic TO. It works great for years. PIA to setup. I remove the tranny to adjust. A bunch of measurements and your done. Follow the instructions.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
clutch slave cylinder skunky_2003 Engine, Transmission and Drivetrain 5 03-16-2005 10:32 AM
Bleeding the clutch slave cylinder? 1992 5 speed strongbo Aerostar 1 01-03-2005 12:52 PM
squeaky clutch slave cylinder psgrn Accord/TSX/Accord Hybrid 4 09-08-2004 07:40 PM
clutch slave cylinder 91redmr2turbo MR2/MR-S 0 05-29-2004 05:04 PM
No clutch slave? Crxce '88 - '91 Civic | CRX | Wagon | Shuttlee 8 02-21-2003 12:14 PM
