Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-11-2005, 10:10 PM
skunky_2003 skunky_2003 is offline
Send a message via AIM to skunky_2003
clutch slave cylinder
alright well advance auto parts is retarded or the guy who catalouges stuff...they cant order me the right CSC. so my question is is there a site that has the oart #'s for everything on the car?...i think i might also be having a problem getting axles that is why i need a site with all the part 3's
Old 03-12-2005, 03:23 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: clutch slave cylinder
I always get slaves from the dealer, never have a problem there. Axles can be tough since some suppliers dont seperate the years, or AWD and FWD properly. This comes up often, but I never paid attention to what the solution is. Then again, your car isnt in your sig, so maybe you forgot to tell the parts counter guy too Good luck.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-12-2005, 11:51 AM
i told the parts guy 95 talon Esi Front wheel drive w/o ABS....do u have a lot of problems from ur slave???
Old 03-12-2005, 10:18 PM
AF - Advisor
I dont have a ur slave, just a regular slave. I replacd it a couple times though.
Kevin Jewer
Old 03-13-2005, 09:59 PM
well i found out it wasnt the clutch slave it was the clutch master cylander....it for some reason if i let it rev up past 6 1/2 the fluid would go bye bye and i wouldnt have pedal and i dont understand why it wasnt leaking but i would have to bleed everything
Old 03-16-2005, 10:32 AM
Erco90Talon Erco90Talon is offline
well
do you have a carquest by you??? i just went there they had a rebuilt one in stock and the reason you loose fluid is because there is a little piston in the master cylinder that has a rubber o-ring type thing just but a rebuild kit from autozone,pepboys or go straight to the dealer comes with piston,rubber o-ring, and spring its not a normal o-ring but im just callin it one its a piece of rubber good luck
