Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-08-2012, 06:38 PM
bsilverado00's Avatar
bsilverado00 bsilverado00 is offline
92 Mustang 5.0 trouble codes
To start off a few months ago my car just suddenly shut off, couldn't retrieve any codes what so ever, scanner not communicating, so replaced ecm with a rebuilt one, car started up and ran fine for a few drives, decided to try a 17 mile drive to work, no problem going, but on the way home, every sharp bump car stumbled, got home thought it might be the maf harness, extended due to meter in fenderwell. tapped meter, changed idle, then check engine light remained on, figured bad maf, changed out meter still have check engine light with following codes- 56, 66, 82 and 98, 56 and 66 are high/ low voltage at maf, 82 secondary air bypass circuit, and 98 hard fault. Any suggestions on where to start
2000 1500 2WD
7" Fabtech Lift
MT Baja MTX's on MT Classic II's
Old 05-09-2012, 04:05 PM
Re: 92 Mustang 5.0 trouble codes
Forgot to mention that car is a convert from aod to t-5, I did cut back the harness and solder in a new wires and plug for the maf. That changed nothing.
2000 1500 2WD
7" Fabtech Lift
89 mustang 5.0 ho code,s 31,66 mondow Mustang Problem Diagnosis 0 04-25-2010 03:25 PM
WTS: 1979, Ford Mustang 5.0 Auto, Coupe, 105,000 orig. miles kevin2e Classifieds 3 12-02-2009 10:49 PM
R.I.P Mustang 5.0 hakka Street Racing 9 06-07-2005 10:56 AM
CRX vs. Mustang 5.0 CRXkid Mustang Talk 12 06-20-2003 01:15 AM
can i beat a old mustang 5.0 liter? crazylee27 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 22 09-17-2002 10:11 PM
