Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 04-30-2012, 03:42 PM
cancarcan cancarcan is offline
noisy at 75+ miles per hour only
My Mom bought this automatic 1999 Corolla new. It has lived in Florida and has now taken up residence in Canada,Ontario. It has 38,500 miles on it,mostly driven at under 70miles per hour. As I drove this car to Canada, I noticed that it became noisy over 70mph and really noisy at 80-85. The noise remained the same from about 80 to 95mph. Putting it in neutral in the Tennessee hills it was much quieter coasting down the hills at high speed. It is not a wheel bearing, alignment or tire problem. The noise seems to be coming from the engine area. I don't understand why it is quiet up to 70? Exhaust ? Transmission? ??? Any Ideas ? I Will have a mechanic look at it but I have had numerous misdiagnosis over the years.
Old 05-08-2012, 12:53 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: noisy at 75+ miles per hour only
Without a description of the noise, it could be anything. Running that fast could be tire noise, wind noise, fan noise.... Take your pick. Wheel bearing noise is usually discernable at much lower speeds. You mentioned it stayed constant as you went above 75 to 95...leads me to fan noise, especially if the A/C was running at the time. Or could be a piece of loose plastic fascia.
We're taking pot shots here until you can describe the noise in more detail.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
93 speedo sits at 140 miles per hour jeffbolin Trans Sport 0 04-11-2006 05:52 AM
84 wont go over 45 miles per hour..pleez help chris_do_it_big Caprice 6 08-20-2005 09:48 AM
Feeling a bump between 10-20 miles per hour dada52 M Bodies 0 08-30-2004 10:29 AM
wont shift and speedo says 0 miles per hour bowdown65 Cutlass Series 9 05-26-2004 11:10 AM
