Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-26-2003, 12:18 PM
bowdown65 bowdown65 is offline
Exclamation wont shift and speedo says 0 miles per hour
i have a 1988 custlass supreme fe3 bought the car a year ago went away for service drove fine before i left, when i came back it wont shift outa first and speedometer doesnt show anything but 0 miles an hour everything else works good.
Old 11-27-2003, 03:48 PM
shekky shekky is offline
Banned
Send a message via MSN to shekky
Re: wont shift and speedo says 0 miles per hour
it could be a speed sensor or the computer. most likely the computer. i had this problem with a cavalier.
Old 12-29-2003, 02:06 PM
latvianrkey latvianrkey is offline
Send a message via AIM to latvianrkey
I am having the same problem. I have replaced the speed sensor on the top of the transmission, but that did not do any good. I have notived that if I drive through a deep puddle everything will work fine for about 10 miles. My question is, is there a wheel speed sensor in the wheel assembly? I know there is a plug behind the hub. Thanks for any help.
Old 01-11-2004, 02:55 AM
pacman46 pacman46 is offline
the plug behind your hub should be the wheel speed sensor for the ABS. system
Old 01-11-2004, 10:09 PM
ok, i changed the front wheel speed sensors for the ABS system and it didn't do anything. Im running out of ideas.....
Old 01-12-2004, 11:55 AM
sir_toke_a_lot sir_toke_a_lot is offline
Send a message via MSN to sir_toke_a_lot
I'm not sure, but if your shift lever is on the steering column, something inside it might be broken. Is it tilt wheel? Tilt wheel column's have a tendency to have the thin metal bars break in them, especially on GM's. My suggestion, would be to buy a new Steering Column and replace your old one. I highly doubt that a computer is the source of your problems either, its most definatly some minor mechanical thing, that will be a bitch to fix or replace. Thats what I'm going to have to do in mine, because it wont shift out of park either.... Does anyone know any cheap ways to nigger rig it up so you can shift it?
Old 01-17-2004, 08:38 PM
tystik tystik is offline
sounds like a bad connection at the speed sensor plug, when it gets wet the water bridges the gap and lets the current flow through the connector
Old 01-18-2004, 04:34 PM
I checked the plugs themselves, and they seem fine. It must be something outside of the engine compartment because the water "bridging the gap" was not inside the compartment. I may need to investigate more.
Old 01-19-2004, 02:25 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
sounds like you fried your Flux Capacitor, better get a new one
Old 05-26-2004, 11:10 AM
thankx
i will try and rig the column and that doesnt work replace puter but thankx for the suggestions
shake at 60 miles per hour in 99 Quest angel1981 Quest | Presage | Serena 1 05-22-2009 06:19 PM
93 speedo sits at 140 miles per hour jeffbolin Trans Sport 0 04-11-2006 05:52 AM
84 wont go over 45 miles per hour..pleez help chris_do_it_big Caprice 6 08-20-2005 09:48 AM
Feeling a bump between 10-20 miles per hour dada52 M Bodies 0 08-30-2004 10:29 AM
