Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-04-2005, 03:48 PM
chris_do_it_big chris_do_it_big is offline
84 wont go over 45 miles per hour..pleez help
When I'm driving the car does not seem to want to go over 45 miles per hour, what could the problem be?
Old 08-06-2005, 12:07 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: 84 wont go over 45 miles per hour..pleez help
What does the car do what it hits 45? Do the RPMs seem to bouce up and down? My 84 had this same problem... turned out to be the fuel filter. Very inexpensive, and easy to replace. Its right in the bottom front of the carb where the fuel line comes in.
Old 08-06-2005, 12:45 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
had same problem with my 88 when i bought it and it was the computer controlled carburetor fouling out the engine, too much fuel, so i have converted to non ECM carb, especially since someone already swapped a non ECM HEI in it already
id say its probably the carb
hjave you pulled any spark plugs yet ?
this i would do and see if plugs are black or white or tan or brown
if they are tan or brown then its not the carb,
if theyre black or white then its carb
could also be black if burning oil and be white if burnign water
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 08-06-2005, 01:13 AM
RamAir81 RamAir81 is offline
Do it big, give me more information; Is the trans shifting OK. What about the exhaust? It could be a clogged Cat Converter.What about tune-up lately, or Timing is not set correctly.
Old 08-15-2005, 03:41 PM
Re: Re: 84 wont go over 45 miles per hour..pleez help
well i just bought the car not even sum weeks ago but when i drove it, it didnt go over 25 miles...once it gets to the 25 mph it doesn go any faster and if i keep trying to go faster it sounds terrible
Old 08-17-2005, 11:34 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
First off, what does the exhaust sound like? A wheezing or whistling noise is a sure sign of a restriction. Listen while someone gives it a little gas. Using a rag, hold it over the tail pipe while someone revs the motor a little. If there is little or no noise or pressure difference, you have a clogged exhaust.
Not the easiest job in the world, but if the exhaust is still suspect, remove the catalytic converter, wire up the rest of the exhaust and go for a very short ride. You'll see a difference right away if the cat was clogged, it will also be very heavy with carbon and soot.
Also take off the air cleaner and make sure the gas pedal linkage opens the carb all the way.
Good luck, Bob
Old 08-20-2005, 09:48 AM
Good luck, Bob
----------------------------------------------------------------------It makes a rugged sounding noise once it reaches 20 miles per hour...no matter how much i push the gas the noise just gets worse.
