Old 04-29-2012, 04:11 PM
hondaguy25822 hondaguy25822 is offline
1999 lumina ltz wont turn over(battery is fine)
Not hearing a click from the start relay either when i turn over the ignition. Any thoughts?
Old 04-29-2012, 07:45 PM
FishFind FishFind is offline
One Hot Shot
Re: 1999 lumina ltz wont turn over(battery is fine)
check wires from the battery to the starter and the ground wire also. Check fuses.
Check your starter.
Old 04-29-2012, 10:19 PM
aleekat aleekat is offline
security light flashing?
Old 04-30-2012, 08:31 AM
Schurkey Schurkey is offline
Starter solenoid clicks, starter doesn't crank???
First Guess: Defective battery or battery cables incapable of transferring heavy current.
Second Guess: Defective starter.
If the solenoid clicks, it should not be the security system which would disable the power to the solenoid "S" terminal.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 05-03-2012, 06:45 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Give the starter a few whacks with a hammer while someone holds the key over to start. Old GM trick. If it fires up, you need a starter.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 05-03-2012, 09:53 PM
Tech II Tech II is offline
Do you have battery power at the "S" terminal of the starter relay with the key in the crank position?
Old 04-30-2013, 11:03 PM
sueyox sueyox is offline
MY 1999 Lumina does the same... drains the batt ( on 2nd new batt) The car alarm got stuck on , so we disconnected IT , pulled fuses ect. but the emerg. lights still bling sporadically... I think THAT may have something to do with it , But once the key is out and its off , it blinks a few min then stops... we noticed today we can move the elec seats while car is off.... Something is draining the battery... is there any hope? thanks for your time Sue
Old 05-01-2013, 09:05 AM
We have two different scenarios here....unfortunately, the original poster never responded to our questions....
Should start your own post.....does the vehicle crank over? If it doesn't because the battery is drained, does it crank with a jump? If it does then you have a parasitic draw, and need to find out which circuit is causing the problem....
You say the car alarm goes off...is this factory or an add on?
1998 lumina ltz starting problems luminakid1992 Lumina 17 05-22-2011 10:55 PM
1999 lumina ltz 3.8 fuel leak pepsiPAID Lumina 1 01-31-2009 10:41 AM
1999 Lumina LTZ Stalling at will mikey1157 Lumina 6 08-07-2007 08:57 AM
1999 Lumina LTZ Brakes Corndog Man Lumina 2 01-10-2007 08:40 PM
1999 Lumina LTZ Guage package RHoschett Lumina 8 02-06-2006 08:11 AM
