Old 02-04-2010, 05:41 PM
luminakid1992 luminakid1992 is offline
1998 lumina ltz starting problems
i have a 1998 lumina ltz. sometime the car will start and sometimes it wont.i also have an automatic start installed on the car. the car does start occasionally and when it does its with either the auto start or with the key. After it starts i am able to shut it off and start it again multiple times with no trouble. But then i wait a couple of hours and the car won't start again. i know the starter is good because i replaced it and the problem did not go away. i think it has something to do with the ignition switch or the VATS system but im not sure how the automatic start is wired in. PLEASE HELP
Thanks
Anthony
Old 02-04-2010, 07:40 PM
maxwedge maxwedge is offline
A990 racer
Re: 1998 lumina ltz starting problems
Welcome to AF. Can we assume no start means it will not turn over, if so when this happens does the security lite on the dash stay on, of course we cannot tell how your remote start is wired in. BTW used to live in Bellmore.
Old 02-05-2010, 05:04 PM
svotta svotta is offline
I had the same exact problem. I have a remote start also. If yove been using regular gas 87 octane your throttle body is dirty and isnt opening. On mine i could drive it all day with no problems then shut it off and a few hours later it wouldnt start until 5 hours later. So bring it to a mechanic and have them check the throttle body ASAP. and if its the throttle body start using 89 octane.
oh cool did u used to go to bellmore train station on friday nights? and yes the security light stays on. every emergency light is on. i think it could be the resistor that the auto start people put in to match the key is going bad but it could also be the neutral safety switch. would u know what color wire the resistor would be wired to??
Old 02-05-2010, 05:06 PM
u mean wont start or wont crank?? my car wont crank
Old 02-05-2010, 05:31 PM
when you turn the key nothing haooens? like no noise from the engine. i brought my car to my mechanic and he checked to see if it was the remote starter and alarm
Old 02-05-2010, 05:34 PM
on turn the key on on and the fuel pump kicks on. but when i turn the key there is no noise and then after i release the key back to the on position the only thing i hear is from the anti lock braking system
Old 02-05-2010, 07:41 PM
have you tried putting it in neutral and starting it?
Old 02-05-2010, 08:01 PM
yea i tryed that and the car still wouldn't start
Old 02-06-2010, 02:43 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Sounds like you need to take it back to the people that installed the auto start system and have them correct the problem.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 05-17-2011, 11:42 AM
schmalen schmalen is offline
Lumina LTZ build 1998 3,8l 6Cy 155256 miles
Hello,
today my Lumi won't start, no noise nothing!, no click(from starter) "silent is the name". No lights everthing ist out of work. I proof all the fuses,they all O.K also i've tried to start in "neutral" what's happend?
for about 5 weeks the same problem, at first i thougt that the Fuel Pump is defect, because if i start, ididn't hear any noise from that pump(somtimes work sometimes no), and therfor i change ist by new one.
and today i know that must be am other problem, has anybody an idea?
kindley regards
schmalen
p.s. excuse me for my bad english
Old 05-18-2011, 03:42 AM
Schurkey Schurkey is offline
Octane has NOTHING to do with throttle body deposits.
"Top Tier" gasoline in ANY octane rating could conceivably help; although it's kind of a stretch to think that added detergent in gasoline could prevent deposits in a dry throttle body.
http://en.wikipedia.org/wiki/Top_Tie...rgent_Gasoline
Do you have power to the small wire at the starter solenoid (connected to the "S" terminal) during cranking?
If you have power to the S terminal when the key is turned to "crank", you've probably got a defective starter or starter solenoid.
If you do NOT have power to the S terminal, there's a wiring problem between the ignition switch and the starter solenoid.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
The Following User Says Thank You to Schurkey For This Useful Post:
schmalen (05-18-2011)
Old 05-18-2011, 03:58 AM
Thanks
Today i bridge the battery, ----and the engine start. Than i let that engine for an our running, stop it ans will start again -- the same problem nothing! no noise no light.
the second time i bridge the battery, engine start directly, but i listen that the fuel pump is running continued, i proofed the relais,-- the relais was very hot! also if i change that Relais with an new one,- the pump is running.
The Fuel Pump is new, i build it in for a couple of weeks
kindley regards
Old 05-18-2011, 04:00 AM
Excuse me double post!
Old 05-18-2011, 09:35 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Thanks
kindley regards
What is the voltage at the battery when the car is running? Need 13.5 - 14 volts or more.
Check battery standing voltage when it does not start also.
I am assuming "bridge the battery" means what we call jump start? Using another battery to boost it? Just so I understand what you're doing...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
The Following User Says Thank You to jeffcoslacker For This Useful Post:
Tags
1998 , automatic , lumina , start , starter
