Old 04-28-2012, 07:21 AM
yankee.23 yankee.23 is offline
trouble with chevy
have 98 chevy p/u 5.7ltr code p1345 says correlation problem ckp cmp sensors changed both and made sure timing chain didnt jump still no start dont have trouble code p1345 schematic any help?
Old 04-28-2012, 08:16 AM
maxwedge maxwedge is offline
A990 racer
Re: trouble with chevy
Do you have spark and injector pulse? Does it pop back? Did you have the dist. out? Not much info provided here.
Old 04-29-2012, 11:23 AM
[quote=maxwedge;6974782]Do you have spark and injector pulse? Does it pop back? Did you have the dist. out? Not much info provided here.[/quotie] fuel pres was good then i had to chahge starter first was ng afterthat and changing cam sensor in dist i had backfire through throttle body( this has the spider injecters under plenum) any way the dist caps on yhese are not round 4 wires come straight out each side the dist cap looked fine by the naked eye but i ohm tested from where spark plug wire goes and traced were it would fire inside the cap . the spark was jumping to diff cylinders inside cap so changed cap rotor and fired right up pretty wierd huh?
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 07:13 AM
troubles with trouble codes grumpyray7 Metro 8 05-20-2008 06:57 AM
Trouble with '89 Cherokee Trouble Codes... citizen@large Cherokee 2 08-04-2006 12:10 PM
Trouble with Chevy extreme starting..help!=) Alnico General Discussion 2 04-10-2005 04:39 PM
96 Bonnie with a/c trouble with ECC playn4keps Bonneville 1 02-10-2005 08:52 PM
