Old 05-12-2008, 09:15 PM
grumpyray7 grumpyray7 is offline
troubles with trouble codes
Can somebody PLEASE tell me what a code 13 is on my 94 metro?
Old 05-13-2008, 04:26 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: troubles with trouble codes
Oxygen sensor
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 05-13-2008, 08:00 AM
lancekilgore lancekilgore is offline
if you do have to change your O2 sensor make sure you get the right one. some 94s with the 1.0 have a single wire and some have a multi wire. mine had a multi wire and to get it it had to come from a 95 model.
Lance
Old 05-13-2008, 08:16 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
The sensor is located on the exhaust manifold on the passenger side of the manifold before the curved pipe.
Old 05-19-2008, 05:57 PM
Thanx! Got that one fixed.... Got a 94 with code 12,timing belt, right? Replaced timing belt, car is running beautiful, but code still flashes and car dies every so often. Tried unhooking battery for about an hour to clear code, but to no avail..... Can this darn code go away without the use of a scanner?
Old 05-19-2008, 07:48 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
code 12 means everythings ok
Old 05-19-2008, 10:13 PM
Car still dies but a minute later it starts right up and runs great down the road a few more miles , then conks out again.... I'm baffled.
Old 05-20-2008, 12:28 AM
sixseas's Avatar
sixseas sixseas is offline
I would try to get a feel for why its shutting down for example is it a clean electrical cutoff or fuel related, more gradual lowering RPM more or less starving out.
I had a problem with one car years ago just couldn’t get it and didn’t know what to do. The car would start, run perfect, and without warning would cut out, but would restart again not right away but in a minute or so.
I started driving the car around in a couple mile square to force the shut down so I could examine it closer. When it finally shut down on me got off the road to see if I could learn more about the problem. Pulled off the fuel line to carb it was bone dry. In that case it was the sock filter.
Old 05-20-2008, 06:57 AM
You did pull out the 30 amp fuse right. you arn't suppose to leave it in there.
possible could be causing the problem if it is in there. Bad gas?
