Old 04-25-2012, 01:28 PM
mtxREDSHO mtxREDSHO is offline
Need help SHO wont start
So i have a 1995 Taurus SHO 3.0l just been rebuilt well apoun start-up well you guessed it... wont start. I've checked all grounds there good and checked/rechecked all connections all good. the thing is when i put key in everything works ac, radio, windows all electrical works it turns over also but it wont start, crank sensor is now so is coilpack, wires, plugs and ive had my DIS module tested and its fine code 113 pops up saying IAT is open or having problem. i tested it with a spark tester and there simply no spark. do you think its a bad PCM? or is circuit not grounding properly? what yall think?
Old 04-25-2012, 11:32 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: Need help SHO wont start
Welcome to the forum!
Is the crankshaft position (CKP) sensor new because of this issue, or new prior to this issue? Why was the CKP sensor replaced? It's relatively common on the older SHOs for the CKP sensor to fail, often caused by a leaking water pump. If the CKP sensor fails, the engine will stall and/or refuse to start depending on when it fails. Have you tried a KOEO test and pulling any diagnostic codes from the car? What is the charging system voltage when attempting to start the car?
-Rod
Old 06-07-2012, 12:24 PM
i_hate_cars38's Avatar
i_hate_cars38 i_hate_cars38 is offline
Lost In The Darkness
screw this
All the great things are simple, and many can be expressed in a single word: freedom, justice, honor, duty, mercy, hope.
Winston Churchill
The most difficult phase of life is not when no one understands you,
it is when you don't understand yourself.
«It's good to know that if I behave strangely enough, society will take full responsibility for me.»
Last edited by i_hate_cars38; 06-07-2012 at 10:30 PM. Reason: have it smarty pants
Old 06-07-2012, 09:39 PM
shorod's Avatar
SHO No Mo
While checking to make sure the pump is running is a good idea, the inertia cutoff switch won't prevent spark like the original poster indicated he doesn't have.
-Rod
Need HELP car wont start. javier 1551 F-Body Problem Diagnosis 1 08-31-2008 02:08 PM
I need HELP car wont start in cold please help bmwjoe Tech Check 1 04-22-2008 11:51 PM
Need Help!! car wont start 1990toyotaPickUp Pick-Up 3 07-17-2004 05:11 PM
Car stuck at gas station need help!Still wont start crx hf '88 - '91 Civic | CRX | Wagon | Shuttlee 14 07-09-2004 05:28 PM
