Old 07-04-2004, 02:24 AM
crx hf crx hf is offline
Car stuck at gas station need help!Still wont start
Well my car cranks over but it doesnt start.It has no spark.I could hear the fuel pump come on (5 seconds).Ive always had starting problems. i have so far replaced my battery,coil,rotor,cap.My cars stuck in the middle of knowhere at a gas station.I need to get it running before people start jacking stuff off my car.The next thing i was gonna replace was the main relay.Does honda test them that way i dont waste my money buying one.
Old 07-04-2004, 02:44 AM
SJ-91LX SJ-91LX is offline
Re: Car stuck at gas station need help!Still wont start
Have you already checked the timing belt?
Old 07-04-2004, 02:48 AM
Ill check that tomorrow its midnight down here.What else could it be.im really getting frustrated.Im just worried becouse i left my car all alone.
Old 07-04-2004, 04:34 AM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Is it like at a pump or in a parking space?
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 07-04-2004, 03:01 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
I woudl check the timing belt. Check your rotor make sure it didnt like fall off. If you hear the fuel pump then its not the main relay.
On a side note main relays from honda are no longer $35, they have gone up to almost $80.
Old 07-07-2004, 02:29 AM
h22hatch91 h22hatch91 is offline
do ur lights come on and everything ?
Old 07-07-2004, 03:40 AM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
if there is no spark.. try the ignitor chip.. that piece is in the dist cap.
Old 07-07-2004, 04:51 PM
Hybrid1990crx's Avatar
Re: Re: Car stuck at gas station need help!Still wont start
I'm glad you ask the most important questions......lol
Old 07-07-2004, 05:09 PM
I already fixed it guys.It was the igniter thanks for all the help
Old 07-07-2004, 08:36 PM
Re: Re: Re: Car stuck at gas station need help!Still wont start
Well if he would have said it was at a pump I was going to say he should stick his car in neutral and push his car to a spot...so people can still get ripped off for gas
bwhahahaha
Old 07-08-2004, 09:58 PM
civicwithawankel civicwithawankel is offline
I think I'm having the same problem as you did, the ignitor is about the only part I haven't checked yet but I'm not sure what to look for... could you please describe what it looks like (color, wires to it, etc)? is that near the toothed wheel for the crankshaft position sensor or whatever that's called?
Old 07-09-2004, 01:21 AM
It looks like a biscuit.Its a little square.There are 2 screws on the outside of the dizzy thats how u get it off.u also have to disconect the little connectors there are 4 pf them.
Old 07-09-2004, 03:53 PM
ok I got it now, thanks
Old 07-09-2004, 03:57 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
stupid igniter....Mine quit at 75,000 miles. There was a recall by Honda on those...If you can prove (most likely thru the VIN) that it was the original, Honda should pay for it.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 07-09-2004, 05:28 PM
Mrock Mrock is offline
Send a message via AIM to Mrock
Actually, I had taken my CRX to the dealership to have the ignitor replaced as well, and they had said they couldn't replace it, because there was a certain year limit, or something along those lines. Long story short- They left me with the ignitor in it's same condition.
How much is the ignitor through the dealership, anyone?
ZC powered '91 CRX...JE 10:1 pistons, Crower rods, Bullfrog cams, Throttle body bored by Gude, Port and polished head, AEM adjustable cam gears, 340cc injectors, MSD SCI ignition, Cold air intake, clutchmaster stage 2 clutch, aluminum flywheel/heavy duty pressure plate, zex nitrous kit.
Waiting to arrive (and install, to get this baby running!)
Walbro fuel pump, PWR radiator, PM7 ECU
Look out, I can run 17's allllll day.
