Go Back   Automotive Forums Car Chat > Automotive Articles > Technical Corner > Tech Check
Old 02-05-2007, 12:24 AM
bmwjoe bmwjoe is offline
I need HELP car wont start in cold please help
I am in chicago visiting for a superbowl party I need my car to start to get home to indiana. It cranks but does not turn over. I kept cranking it then eventually it would like die after about a minute and start just clicking. I do not know that much about cars and am stuck here and its very important I fix it and get it home. I have pushed it in a garage not sure what to do next. I just got the battery last year so I think its good any suggetions or ideas on what I should try next I am up for anything. 93 bmw 325i
Thanks,
joe
Old 04-22-2008, 10:51 PM
rammit53 rammit53 is offline
Re: I need HELP car wont start in cold please help
well i would first suggest not cranking it for so long unless you happen to have a few extra bucks for a starter. when you crank untill the vehicle "clicks" means that you have extinguished the batteries ability to start your car. the clicking sound is the ignition relay continuously engaging but the battery does not have enough charge to maintain a connection. your going to need to either charge your battery, or buy a new one. in order for an engine to start it must be turned at a minimum of four hundred RPM's, if your battery doesn't have that kind of power then it will just turn until it dies. try a new battery and see what you get. good luck
