Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-03-2003, 11:50 AM
frozen_Joth frozen_Joth is offline
Easily Distracted
Send a message via AIM to frozen_Joth
N20 Question
I dont know much about nitrous, in fact I have never actually seen a nitrous kit installed(in person). I was thinking about maybe investing in a N20 kit soon and I need to know a couple things. Do you only want to use it in 5th gear? What about in an auto? The reason I ask is beacuse it seems like if you hit the nitrous in 3rd or 4th gear you would rev to fast to change gears quick enough to gain speed. But I don't have a single clue to how you would go about it. And about how many shots do you get in a medium-sized tank? And one last question which just may the dumbest, do you hold the button for a sec. or just hit it and let go? Any info would be appreciated.
'92 blue Civic Si
-B17a
-Carbon fiber intake, full exhaust
-Short throw, lowered
Old 06-03-2003, 03:20 PM
PWMAN's Avatar
PWMAN PWMAN is offline
You can usually hold it for about 15 seconds. Depends on how much you are putting in. So lets just assume a 50 shot which is 2 lbs per minute. The average bottle is ten pounds. So 4 times a minute, times five would give you 20 times you can hit it before needing refilled.
Old 06-03-2003, 03:23 PM
Cronic Cronic is offline
Send a message via AIM to Cronic
n2o
Doesn't matter which gear your in. It will speed things up a bit though. Not so much as you can't compensate by shifting.
Old 06-03-2003, 03:37 PM
Mr. Anderson's Avatar
Mr. Anderson Mr. Anderson is offline
Well from personal experience...no you definetly do not want to use N2O in fifth gear as that is an overdrive gear and can't handle the power too well. First gear is completely useless unless you like to buy tires alot, or you just want to put on a smoke show. What kind of car are you considering putting this in? My Zex kit activates at WOT (Wide Open Throttle) which is activated by a toggle switch (you're watching too many movies). So you hit the toggle and when you gun it the NOS kicks in. What I do is activate the switch right after I shift into second.. get up to about 4k and punch it......zoom zoom! When your done racing flip the toggle off. Yes there are such things as the push buttons, but you don't need that. PWMAN hit the refills on the head.. however when your tank gets down to about 3lbs or less your nitrous isn't performing to what it is capable of because of lost pressure. Below 2lbs is close to nothing at all! And to furthermore.. if you are going to be using this on the street alot (which you shouldn't be) invest in a remote bottle opener, of course if it is going in a trunk? It's a pain in the ass when some dipshit pulls next to you and your bottle is off! Hope I helped........
[img]
Old 06-03-2003, 03:44 PM
n2o
Depending on the kit you can hold WOT or the button down as long as you like. It's not recommended however.
5th gear will not "wear out" just cause it's an overdrive, It's not weaker then any other gear, in fact, this should be the last gear that breaks because it puts so much less stress on the tranny being as it's so long.
Old 06-03-2003, 03:47 PM
hmm.. that's interesting! Of course, that part of my answer was based on someone else suggestion from here so I just took heed of it. If you were going to use it in fifth gear, probably wouldn't be a good idea until you hit at least 4500 or 5k right? Whatta ya think?
[img]
Old 06-03-2003, 03:54 PM
PWMAN's Avatar
That is true, I forgot about that.
Old 06-03-2003, 03:59 PM
n2o
A friend of mine runs a nitrogen bottle to keep the pressure in the n2o bottle up. He uses a seperate solenoid to transfer the gas.
Old 06-03-2003, 04:01 PM
Interesting........got any links to that!? Never heard of it before...
[img]
Old 06-03-2003, 04:52 PM
Easily Distracted
o.k. thanks for the help, damn this forum kicks ass.
'92 blue Civic Si
-B17a
Old 06-03-2003, 06:30 PM
Link.
http://www.tamparacing.com/forums/sh...light=nitrogen
Old 06-07-2003, 09:29 AM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Don't spray in 5th gear the reason is b/c the car needs to be in a low gear so that the car can speed up quickly, when in 5th gear though it won't and you will do damage to the motor not the tranny the extra strain will be put on the motor. Also I would recomend a WOT switch. If you don't install a WOT swirch then be sure to never spray any other time than WIDE OPEN THROTTLE! I have been using N20 for about 2yrs now and I have had no serious problems my internals are fine and compression on my motor is extremely good for the situation(192,190,190,192) spec is (199,199,199,199) but the motor has 135k miles on it also so I think it is rather excellent compression numbers.
Old 06-07-2003, 11:57 AM
It will not matter what gear your in.
Nothing left but a force fed hamster...
Old 06-07-2003, 12:17 PM
iceiso iceiso is offline
Send a message via AIM to iceiso
aha ha ha, really really stupid question but it's kinda relevant...
is wide open throttle redline (or close to it) or is it when your foot is when the gas pedal is completely depressed?
Old 06-07-2003, 12:30 PM
whtteg's Avatar
Ok pall you go ahead and spray in 5th gear and see how long that lasts! You will either be replacing clutch, or piston rings b/c when you try spraying in 5th gear your clutch fries itself and the engine redlines hitting the fuel cutoff and suddenly there is a lean condition and you know the rest and if you don't then you don't know what you are talking about and should stay away from giving ppl advice on somethng you know nothing about.
iceiso:
WOT is when the pedal is pressed to the floor ( the throttle plate is turned horizontal)
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
N20/Turbo/Supercharger - Reliable? EG Head Forced Induction 2 03-08-2002 10:40 PM
B&M Commandflo for N20?? phattycrx Forced Induction 7 01-17-2002 09:35 PM
