Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-14-2002, 12:18 AM
phattycrx phattycrx is offline
Question B&M Commandflo for N20??
its cheap but only goes to 60 psi??? is this going to be enough to run a 75 shot on or no??? should i just get an AEM FPR??? or maybe even the vortech one that does to 70??? any one with expirence or ideas on what the fuel pressure should be?? thanks.........
Old 01-15-2002, 02:51 PM
pvang31019 pvang31019 is offline
it's fine, I used one with my nitrous setup too...and you won't need to go all the way up to 60psi...
Old 01-15-2002, 03:10 PM
Smile thanks
thanks then i will go with that instead of spending almost 200 on the aem one...thanks
Old 01-16-2002, 08:30 AM
FLAWLESS FLAWLESS is offline
Send a message via AIM to FLAWLESS
You'll still keep it adjusted somewhere in the neighborhood of 35psi or so. The only diff between the B&M and others besides price is the B&M requires you to cut the top off the stock regulator (so break out the hacksaw) and it piggybacks on top of the stock. Others are direct replacements.
It's cake to install if you know how to read directions. $50 is much better than $200 and it will work great.
Get the gauge too...and have it tuned on a dyno if possible or it's just guesswork otherwise.
Old 01-16-2002, 10:56 AM
thanks
cool...sounds good
Old 01-17-2002, 04:38 PM
trmi-nate trmi-nate is offline
where can you get this for $50?
1997 Milano Red Civic EX
17" Konig Caffeines
Sportlines/KYB AGX
AEM CAI/DC 4-2-1/Greddy EVO
Short Shifter/ Indiglos
Old 01-17-2002, 05:08 PM
Try Summit Racing I thought I paid $50-$60 something like that. Check around for it.
Old 01-17-2002, 09:35 PM
summit has it for 60 and the gauge for 30...real cheap
