MT 2500:) 99 5.7 cuts out only at 3000rpm
MT 2500 Where are you
I've got a weird one. 99 Chevy 5.7 dually dump truck. The engine cuts out while driving at 3000rpms only. If you keep your foot in it it goes away at 3200. Does it in any gear(auto). Also, stopped and in park, it will do it at 4000rpms. Acts like a rev limiter. Fuel pressure does not change (60-62psi) when this happens, does it in open or closed loop. I disconnected the maf and no change. I've installed new cap, rotor, plugs, wires, coil, module(all original with 165K), no change. Runs sensational until 3K rpms. Any thoughts????
Re: MT 2500:) 99 5.7 cuts out only at 3000rpm
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
There should be no rotational play at all??? Like the advance play you would feel in an older style distributor?
That is correct. Zip, Zero, Nada & None.
I'll check that soon and get back to ya with my findings. Thanks!
I had a similar problem with a '97 it ended up being the coolant temp sensor. It can be checked with a scanner. If you replace it get a good one from the dealer not a cheap aftermarket one.
NO 4 N JUNK ![]() 1994 GMC K1500 XC 5.7L 2008 Chevy Impala LTZ |
I haven't had a chance to work on this vehicle again yet but I'll keep that in mind. Thanks!
Finally got around to this vehicle again. There is PLENTY of clockwise/counterclockwise play in the rotor/gear. Sounds like distributor time
You can replace just the drive gear since that is probably what is worn out. Much cheaper than the a new distributor.
//2000CAYukon |
Thank you in advance. |
Also has a new fuel pump (62psi), fuel filter.. Definitely feels like it's loosing spark. New distributor came with new module, cap, rotor.
I've got an Actron CP9580 with real time data. Anything I should be looking for???
Have you driven it with fuel pressure gauge attached? Would be interesting to see what the pressure is doing when it cuts out at 3000 RPM. If it is electrical, it could be coil or CPS (crank position sensor).
Good Luck. //2000CAYukon |
FIXED! Crank sensor. Keep this odd one in your memory bank. Thanks to all!
Saw your post after I fixed it. Thank you though!
