Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 12-19-2005, 09:31 AM
nopsen nopsen is offline
Question 98 3.5 intermittent cut-out
1998 3.5 SOHC Trooper, new fuel pump, new fuel pump relay, new engine relay, runs great except for unexpected engine cut-out. Usually restarts itself instantly. Sometimes stalls completely, but restarts without a problem. Any suggestions?
Old 12-19-2005, 09:55 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 98 3.5 intermittent cut-out
most likely the intake manifold gasket.
search on it here.
and read up on the FAQ's
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-19-2005, 11:54 AM
Thanks amigo, but does the intake manifold gasket make sense if the engine never runs rough. This is like someone reaches over and turns off the key, then turns it right back on?
Old 12-19-2005, 02:24 PM
Isuzu Guy
http://isuzufaq.ibctech.ca/#faq45
-Ryan
Isuzu Moderator
Car Show Tips
Old 12-19-2005, 03:41 PM
rodeo02 rodeo02 is offline
Unrelated, but your 3.5L is a DOHC. Are you getting a check engine light? Have you scanned for pending codes? No CEL, I'd guess at the IMG, or a possible low system voltage condition (bad battery, or alternator). You need to see 14VAC across the battery with a hand-held voltmeter with the truck idling. Could also be a stuck idle air control valve (IAC). Pre 2000's have IAC's.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
