Go Back   Automotive Forums Car Chat > Saturn > Ion
Old 04-21-2012, 02:12 PM
3mikeman 3mikeman is offline
P 0480 Code
2007 Saturn ion 2.2 Ecotec
I had to replace the fan assembly motor it was burned out. Now i still get the same code. I would erase it and as soon as i start the engine the SES light would come on. The a/c is off and all other fan controls are off. Could this be a PCM problem? Also i'm not getting 12v at the fan plug with key on engine off but a/c button on. The A/C clutch doesn't engage either it think it's low a charge but the cooling fan should work either way right?
Old 04-21-2012, 08:45 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: P 0480 Code
Here is some info on the code, maybe it will help?
http://www.bba-reman.com/content.asp..._P0480_WITH_AC
P0304 code, rough idle, better since code charlie3 Contour 5 07-05-2006 12:26 PM
ODB code 33 and code 44 david-b Eclipse Problem Diagnosis 1 02-12-2006 08:27 PM
code 10 1988 ford separator code AbbyFord F Series 1 12-19-2005 05:10 PM
airbag code B2292 & code 33 ? 2003 Taurus ejb22 Taurus | Taurus Wagon 2 12-13-2005 04:08 PM
95 Z Code same as 94 Z Code? GeneP S-10 4 12-13-2005 03:03 PM
