Go Back   Automotive Forums Car Chat > Ford > Contour
Old 11-28-2005, 10:07 PM
charlie3 charlie3 is offline
P0304 code, rough idle, better since code
96 Ford Contour 2.0 105000 miles
About 6 months ago, engine locked up, would not crank when the plastic idle pulley for the timing belt wedged against the crank. Had a good garage replace timing belt, pulley, and water pump. Also, for about a year, I have to add 1 quart of antifreeze per month.
Now for the latest and have seen many post similar, except no engine codes mentioned in the other posts...
Has been idleing rough, shaking when in drive, almost stalls for 6 months. Engine seems to have good power and acceleration otherwise.
Last week, after driving about 20 miles, the engine just about died (stumble/shake) when pulling out from a stop. I thought I was ready for a tow. But then the check engine light came on and it started running normal. (never stalled)
In fact, now that the light is on, it idles great.
So, I thought a simple scan would tell me what sensor was failed, but the only scan code was P0304 which says cylinder 4 misfired.
I checked the plugs, they look great and re-gapped them. The wires look good, boots clean.
My confusion is....since the light is on, it runs better. This tells me the computer is using default values for some sensor that was detected as failed. But the scan code is not telling me that.
If it was bad wires or plugs, I don't believe the computer could change that.
Hope we can find what is going on with these rough idle problems so many contours have.
Old 11-28-2005, 10:12 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
if you disconnect the battery to reset the pcm and clear the CEL's, does it go back to idling rough?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-28-2005, 10:19 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: P0304 code, rough idle, better since code
all zetecs idle rough
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 11-29-2005, 10:32 PM
Cleared codes, rough idle returns
I was able to borrow a snap-on scan tool, ran several tests and passed them all. The P0304 was the only thing in any memory I could find. I ran it at idle before and after clearing the codes with the scan tool. After I cleared the codes, it ran rough again, like before there was a code. Now, of course, I have a P1000 code until the emmisions re-learn.
With the scan tool, I can look at all the sensors, but who knows what are normal numbers for all that data??
Like the other reply, maybe it is just the way zetecs run when over 100,000miles.
Old 11-30-2005, 03:22 PM
given the P1000 code, sounds like its time for a new MAF. That would definetely cause bad driveability if thats messed up. Try unplugging the MAF and see if it idles any better on 'limp' mode.
"The CEG Nazi"
www.contour.org
Old 07-05-2006, 12:26 PM
Working better now for last 3 months.
Timing belt broke and needed to be replaced again. Was done just one year earlier. A year ago, the plastic idler on the timing belt broke forcing the replacement. This year, one of the plastic pulleys on the timing belt broke. My thought...replace all three plastic pulleys when servicing. Advance auto stocked a 3 pulley kit.
Anyway, when replacing, noticed that I had to pick the alignment of the crank, either between the timing marks or just after the second timing mark. I picked the between timing marks. (I didn't want to break loose the toothed gears on the cams.) Now it idles great and runs great. It still has some shake at idle and has some surging at certain light loads, but I am not worried about stall.
I can't be sure, but perhaps a year ago when the shop replaced the belt, perhaps they were one tooth off on the timing belt????
