Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-12-2006, 12:20 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question ODB code 33 and code 44
For my other car;
Just in general...
A code 33 means MAP sensor or circuit - excessive airflow indicated.
A code 44 means O2 sensor or circuit - lean exhaust detected.
So, if I'm getting these codes, would the solution be to replace the MAP sensor? It seems to me that the MAP would then help richen up the exhaust alittle.
When I was installing my SAFC and ended up accidentially not hooking up the MAP, the car idled poorly at times, and died. It also ran fine at times though. (yeah, I mess around like that). My other car is idling funny, and dies. But at times, it runs fine though. This is where I got the 2 codes above. So should I replace the MAP and see what happens?
Thanks.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-12-2006, 09:27 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: ODB code 33 and code 44
i say go for it.
95 Talon TSI AWD
97 Eclipse GST
