Old 04-15-2012, 11:38 PM
Damondogg Damondogg is offline
Question 99 S10 has a delay....
My truck has a short in it. I've noticed this delay for the past few months.
Takes a few seconds when I'm cranking it, then it finally starts. Could it
be the alternator that I need replaced? It's not the battery, cause I'm getting plenty of juice.
Old 04-17-2012, 07:25 PM
j cAT j cAT is offline
Re: 99 S10 has a delay....
longer than normal , starting of the engine could be fuel delivery. fuel filter, old plugs. high resistance plug wires / weak spark , worn distributor cap/rotor.
I would guess a weak spark would cause a longer than normal cranking before start.
just to be sure have the battery LOAD tested .a weak battery will cause poor spark also.
84 S10 has dead spot when you take off adam08784 Problem Diagnosis 2 11-02-2009 06:26 AM
S10 has plenty of oil, but oil pressure is low Ducaire Problem Diagnosis 6 04-09-2007 10:04 AM
Ticking/Clanking noise in the rear?? 1998 S10 has new problems... ceremonialdagger S-10 5 05-11-2006 10:44 AM
95 S10 has fuel in oil scott57 S-10 5 04-02-2004 07:28 PM
2000 S10 has no power pulling away when hot pwrenplan S-10 1 11-19-2003 03:58 AM
