Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-14-2012, 05:12 PM
radrodder04 radrodder04 is offline
Misfire cylinder 1
I have a 99 Saturn SL2/auto. Cylinder 1 will not fire. It has spark to the end of the plug. But the cylinder will not fire. No oil is getting on the plug it isn't fouling out. A brand new plug doesn't help at all. The cylinder is DEAD!
Old 04-15-2012, 02:28 PM
Cat Fuzz Cat Fuzz is offline
Re: Misfire cylinder 1
Fuel injector maybe.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 04-15-2012, 06:23 PM
I'll check that 1st, because my next door neighbor says he thinks it's lost compression in cyl. 1 and I don't like his diagnosis.
Old 04-15-2012, 07:55 PM
A compression test is easy. No compression, no fire.
Old 04-18-2012, 11:35 AM
So no compression means Rings or valves?
Old 04-20-2012, 12:05 AM
Most likely. You could have burned piston. I've seen holes burned clear through a piston top before. A bent valve could cause no compression but valves don't just bend without something bending them, like, foreign matter getting in the cylinder or the engine being ran with the valve timing off, like when a timing chain breaks or is improperly installed.
Old 04-22-2012, 09:26 AM
denisond3 denisond3 is offline
My first check would be to see if the connector to the injector for #1 cylinder is truly and fully seated onto the injector - and clicked in place. After that I would do a compression check.
If the engine still runs on the other 3 cylinders, I dont imagine it could be a problem of valve timing or a timing chain that has slipped. If it ever slipped enough to bend a valve - the engine surely would no longer run.
Your compression reading should be nicely above 110 psi, and not vary a lot from cyl #1 through #4.
Old 04-22-2012, 08:22 PM
Make sure your ignition wires are in the correct order.
Old 10-12-2012, 02:33 PM
drew300 drew300 is offline
I had the intake manifold gasket leak, which caused a misfire on #1.
you can check it by spraying WD-40 or throttle body cleaner around the manifold / head.
Misfiring Cylinder 4 on 2002 Merc Sable reedjasonf Sable 3 05-08-2012 01:01 PM
mercury villager 1999 random multiple cylinder misfire moshawh101 Villager 0 05-10-2011 10:10 PM
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 08:49 AM
P0305 Cylinder 5 Misfire wmuwop Explorer | Explorer Sport Trac 3 03-31-2009 06:40 AM
Weird #3 cylinder misfire gesellman Trooper | SLX | Bighorn | Wizard 2 03-06-2009 11:31 PM
