Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 05-10-2011, 11:10 PM
moshawh101 moshawh101 is offline
mercury villager 1999 random multiple cylinder misfire
I have a 1999 mercury villager that is showing a random multiple cylinder misfire code and an o2 sensor code. The vehicle has a small leak on the exhaust between the catalytic converters and I'm not sure if this would be affecting the back pressure enough to make the engine throw these codes. Also I replaced the distributor and tried the original placement of the distributor and multiple placements. I am going to get the exhaust fixed and put either b12 cleaner/ seafoam cleaner through the engine and fuel system to see if anything will clear up the fuel system/ make it slightly better. The vehicle runs rough at an idle but runs smooth when reving and at higher speeds above approx 1300+RPM's. Are there any other explanations to why it would be running rough?
Random/Multiple Cylinder Misfire Riverdog07 Cavalier Problem Diagnosis 5 11-05-2007 01:32 AM
P0300-Random/Multiple Cylinder Misfire questions-Please help! quicky422 Alero 3 07-10-2007 06:23 PM
Random/multiple cylinder misfire Silverado Brethern C/K 13 12-13-2005 07:29 PM
Random/Multiple cylinder misfire insanesnwbrdr Camaro Discussions 2 11-17-2005 10:49 PM
random multiple cylinder misfire rwp212 Cavalier 2 06-25-2005 01:02 PM
Tags
cylinder , misfire , multiple , random
