Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 04-03-2012, 02:42 AM
reedjasonf reedjasonf is offline
Question Misfiring Cylinder 4 on 2002 Merc Sable
I have a 2002 Merc Sable Lx Premium sedan. It has the 6 Cyl, 24V DOHC engine and ~110,000 miles.
First of all, the OBD codes I get at the auto parts store is P1120, P1121. I replaced the TPS twice which is from code P1120 (Throttle Position Sensor - low input) and still having the same problems.
The car runs a little rough. However, when I sit at a red light or stop sign the RPMs run low and eventually the car will shake and the engine light blinks. The OBD also says it detects a misfire on startup (first 1000 rpm). Also, when I'm idling the headlights and dash lights are more dim. When I give the car some gas the lights get brighter which doesn't seem normal but I don't know if it's related.
I already mentioned that I've replaced the TPS. I've also replaced the spark plugs and wires and a mechanic told me that the fuel rail is getting good pressure. I've had the alternator and battery both tested at the auto parts store and they check out fine. I've also checked the ignition system myself using a voltmeter according to the Haynes manual instructions. Battery voltage is 12.4V off and 14.4V idle.
I've been driving the vehicle but when I know I'll be idling for more than a few seconds I just have to keep the RPMs up so the car won't misfire. The only thing I could think of testing at this point is the coil pack but haven't had a chance yet. Any other suggestions?
Old 05-07-2012, 03:40 PM
AvalonJohn AvalonJohn is offline
Re: Misfiring Cylinder 4 on 2002 Merc Sable
With the lights dimming it almost sounds like relays? If you've checked battery, alternator, ignition coil, etc I'm look on the Ford Windstar Forum. Many Windstars have had this problem. I had it too with my Winnie, can't really remember if I fixed though? No longer have the van.
Good luck,
AJ
Old 05-07-2012, 08:25 PM
AvalonJohn, can you be more specific as to which relay it might be? You mean the relays that are in the fuse box?
Thanks for the info.
Old 05-08-2012, 02:01 PM
Here is the Windstar thread .... 12 Ounce helped me out. Not sure if same cause for Sable? See Link on Windstar fourm.
http://www.automotiveforums.com/vbul...lights+dimming
mercury villager 1999 random multiple cylinder misfire moshawh101 Villager 0 05-10-2011 11:10 PM
2002 Passat 2.8 wont start and only hitting on one cylinder jenseay72 '97+ 0 01-08-2011 03:33 PM
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 09:49 AM
P0305 Cylinder 5 Misfire wmuwop Explorer | Explorer Sport Trac 3 03-31-2009 07:40 AM
Weird #3 cylinder misfire gesellman Trooper | SLX | Bighorn | Wizard 2 03-07-2009 12:31 AM
Tags
misfire , p1120 , p1121 , tps
