Old 04-12-2012, 09:59 PM
roque11 roque11 is offline
Oil gaskets
I have a question regarding leaking oil gaskets leaking. iIt's the pan looking object up front, ahead of the trans pan and under the engine. Thus far there is no leaks seen on the ground. Is this considered serious and in urgent need of a repair? A few people who have looked underneath at oil change places and an auto parts center seem to think it doesn't look serious or anything that can be urgent and that some are common like that eventually Should I be concerned?
Old 04-12-2012, 10:15 PM
tempfixit tempfixit is offline
Re: Oil gaskets
If your oil level does not vary and no spots on the ground I would not get concerned about it. Just monitor your oil level and watch for any fresh oil spots where parked, if none visible you are good to go in my opinion.
Old 04-14-2012, 03:33 PM
Willyum Willyum is offline
Re: Oil gaskets
My '02 Vulcan oil pan was leaking for some time. The drips burn off on the exhaust for the most part and after while the smell of oil in the cabin became objectionable. I bought a couple stop leak treatments at Wal-Mart that helped considerable but they don't last long. The pan gasket change isn't bad nor expensive if you DIY.
Old 04-14-2012, 09:55 PM
Re: Oil gaskets
Also, is it bad if exhausts are dripping in the front end?
Old 04-16-2012, 03:19 PM
Re: Oil gaskets
Rogue11, Don't think your last post makes sense
Old 04-16-2012, 08:53 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Oil gaskets
Are you referring to the mufflers, and drips from the front of the mufflers? If so, there are usually little drain holes there to allow condensation to drip rather than rust out the internals. If your car only makes very short trips, it's not uncommon for moisture to drip from the mufflers and tail pipe. If you make plenty of long trips, then you probably have some other issue such as a coolant temp sensor that is out of range, a misfire, etc.
-Rod
Losing coolant and oil Rkeefer23 F-Body Problem Diagnosis 1 05-08-2011 09:37 AM
Oil Pan Gasket? ken_man_1 F Series 8 12-03-2010 07:30 AM
Oil Pan Gasket- cork gasket or seal packing - or both? floridacamry Camry/Camry Hybrid/Vista 4 09-06-2009 09:47 AM
White milky oil on oil cap. Lower intake manifold gaskets anthonyalan Grand AM 3 04-07-2007 02:35 PM
tranny gasket/oil pan gasket mhowe1182 Blazer 5 03-20-2006 02:53 PM
