Old 04-08-2012, 06:14 PM
Beaner81 Beaner81 is offline
07 2500HD 6.6L Brake Light Out
I just bought an 07 2500HD Duramax and the right brake light and blinker dont work. I swapped bulbs and checked the fuses on drivers side dash and under hood drivers side, all looks ok but it still doesnt work. No voltage at the bulb. Is there another fuse somewhere I am missing?
Old 04-08-2012, 06:34 PM
777stickman 777stickman is offline
Re: 07 2500HD 6.6L Brake Light Out
Not sure with your '07, but my '98 Sub rear lights are in a circuit board that fails occasionally.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 04-08-2012, 08:21 PM
j cAT j cAT is offline
since the one side is out follow the wires back from rear fixture to the rear junction block. this is where it usually gets damaged/open.
Old 04-19-2012, 06:59 PM
ok found it, under the fuse block in the engine compartment there are 5 plugs. One of the plugs has 2 of the 4 clips that hold it up to the underside of the fuse block broken so it was settling down. Found a replacement plug for $20. Now I just need to find 1 of the 2 clips that holds down the fuse block without buying a whole new fuse block.
Old 04-19-2012, 07:08 PM
just be careful with these small wires. the wires under this fuse block go every where. surprised , with your vehicles age , you have issues here. my vehicle I had a rodent nest under the fuse block . others have had 4wd issues, and fuel guage because of wires/connectors broken there........
I am surprised you had to go that far back.
Old 04-19-2012, 07:20 PM
So my diagnosis of the original cause is that 1 of the 2 large grey clips that hold down the fuse block was missing allowing the back of the fuse block to raise and lower a little. The 4 tabs on the plugs dont actually clip onto the fuse block but sit in grooves on the under bracket below the fuse block holding it up agains the bottom of the fuse block. My thought is that the fuse block moving up and down allowed 2 of the tabs to fall out of the groove and get pinched and eventually broke. now with 2 tabs missing the side of the plug it pulls away from the fuse block enough to break contact.
Again I just bought this truck so I don't know how long the clamps have been missing but I am fairly confident once I replace the plug and find a clamp to hold the fuse block down this will not happen again, until the rodents move in...
Thanks for the help
Old 04-19-2012, 07:26 PM
one forum member removed the uper intake manifold. when this was worked he put stress on the wire harness and broke some wires under the fuse block.
No Brake Lights or Hazard Lights acidcrashdburnd Eighty Eight 1 06-06-2011 11:41 AM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 11:19 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 01:11 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 01:39 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 09:49 AM
