Old 04-07-2012, 03:33 PM
pcabn pcabn is offline
99 Silverado Window Issue
Put my window down today heard something break I was able to get window back up. Don't know what I am in for when I start taking this apart. Any advice I would appreciate. It is the drivers door. Thanks
Old 04-07-2012, 03:58 PM
j cAT j cAT is offline
Re: 99 Silverado Window Issue
cable snapped. these caBLES on the vehicles I worked rust.
I got the window regulators at 1A AUTO.
make sure you grease the cables when installing new.
Old 04-14-2012, 08:24 AM
Replaced regulator good video at 1a auto. It seems to go up slow cant figure it out but it appears to be operating correctly not binding up I did grease the cables and slides. I will see what happens.
Old 04-14-2012, 09:10 AM
DeltaP DeltaP is offline
I'd use a lithium grease on the cable but only silicone spray on the door tracks. Other grases will mix with dirt in the tracks or swell rubber parts and put a drag on the glass. Check to see if the glass has excess lateral play in the tracks, (move the glass fore and aft). That would indicate wear of other parts or an adjustment needed.
Old 04-14-2012, 10:43 AM
I forgot to mention to use silicone spray on the rubber guides.
since you replaced the complete assy the only resistance created would be the rubber parts . I spray all these rubber gaskets/seals every year with the silicone spray . wipe off excess after 30 min. let it get absorbed. over time if not too harded it should soften the rubber and seal/slide easier.
98 Grand AM SE - Power window intermittent issues drives window only Dadwith2boys Grand AM 2 07-24-2010 12:58 PM
1998 Jeep Cherokee Classic - Electric Window Issues Dre1989 Cherokee 1 06-17-2010 12:57 PM
Can't put gas in my 06 Silverado ajdesigns Silverado 9 06-01-2010 02:16 PM
99 Silverado Electrical Issue? dansan C/K 1 04-26-2004 12:18 AM
