Old 04-25-2004, 08:10 PM
dansan dansan is offline
Angry 99 Silverado Electrical Issue?
I have been having trouble with the truck going completely dead when I turn the key to the start position. Everything just goes dead. I was told to disconnect he battery and reconnect - before starting or using any electrical power, press the unlock button 3 times within 5 seconds. At first this worked and the truck would turn over and start. But now it just clicks once and is dead. No lights or dash lights. Any ideas anyone?
Old 04-26-2004, 01:18 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 99 Silverado Electrical Issue?
double check the battery connections, they have to be clean and tight. you might have something killing your battery or a bad battery. does it start off a jump? make sure the alternator wires and starter wires are tight. as well as where the negative battery cable attatches to the block.
good luck
