Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-05-2012, 11:53 AM
twisted27 twisted27 is offline
Exclamation 97 eclipse non turbo mt base=no power to pump
so i'am not getting any power to the fuel pump, checked if getting power to relays=fine, checked relays= fine, dont know what else it could be? ecu?
Old 04-05-2012, 02:12 PM
steviek's Avatar
steviek steviek is offline
Re: 97 eclipse non turbo mt base=no power to pump
Unlikely the ecu.
I would first suggest rewiring the fuel pump. Have you checked if there is voltage at the pump? If there is then it could very well be the pump itself. if there is not then the rewiring will solve the problem.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 04-05-2012, 02:45 PM
k so i dont think you understand, i do NOT have power at the pump (not getting any volts) as i stated before. i also get continuity from the wires to the pump. so i dont need to rewire the pump.
Old 04-05-2012, 05:21 PM
steviek's Avatar
Pin 74 from the ecu is white with red stripe. It goes to your fuel pump relay. I guess you should test to see if has voltage then.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 04-05-2012, 08:46 PM
so i have power to the relays
Old 04-05-2012, 09:52 PM
steviek's Avatar
Well if what you're saying is you have voltage right up to the pump and its not turning on then it must be the pump? But you say you aren't getting power to the pump. Yet you have power at the relay and the wires to the pump have continuity. SO at what point does the power ground out?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
The Following User Says Thank You to steviek For This Useful Post:
twisted27 (04-05-2012)
Old 04-05-2012, 10:44 PM
i know right, thats what im trying to figure out lol. so it has to be somewhere between the relays and pump guess i will dive into it tomarrow thanxs for your help
Old 04-05-2012, 10:54 PM
steviek's Avatar
FWIW I'm confident that something like this would cure your problem.
I have this exact kit on my car...
http://www.ebay.ca/itm/DSM-FUEL-PUMP...item3cb685b0d4
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 04-05-2012, 10:58 PM
yeah think that is a switch if im not mistaken and didnt want to have to flip a switch thats all thanx for the option tho
Old 04-05-2012, 11:02 PM
steviek's Avatar
what do you mean switch?
there is def no toggle swtich
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 04-05-2012, 11:11 PM
what is it ? does it just wire it to a diff relay or somthing?
Old 04-05-2012, 11:21 PM
steviek's Avatar
yea it comes with its own relay. You wire the power source direct from your battery to your new relay. Then you splice a couple of the existing wires attached to the old relay attach those to the new relay and your done.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 04-06-2012, 06:14 AM
ned032002's Avatar
ned032002 ned032002 is offline
I had that same kit on my DSM and it is super easy to install. There's only 4 wires that hook into it. You run a 12v from your battery to one post, a ground to the chassis and to one of the posts, then to the pump itself there's the power wire, you cut that and run one end to one of the posts and the other end to the 4th post. So the power coming to the pump is cut and then it is ran to pass through the relay that uses the 12v power to amplify the power going to the pump. Really easy to do and can be completely accomplished in about an hour or so.
...and there is no toggle switch
Old 04-06-2012, 07:27 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
You need to check and see if you are getting power to the coil pack and injectors. The ASD relay provides power to the fuel pump, injectors, and coil. If you are getting power to everything but the pump then you have a wiring issue or the pump is bad. If nothing has power (Note that they will only have power when priming on first power up and when cranking) Then the ECU in the car is not turning the relay on… Meaning that you have another issue you need to be looking for. Could be a bad crank position sensor etc.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-06-2012, 07:20 PM
so would the coil pack get power with the key in the on position or do i have to crank it?
Want to turbo a 96 Eclipse 2.0 non turbo donidavis Engine, Transmission and Drivetrain 7 12-02-2010 08:23 AM
96 Eclipse Rs Non-turbo Vacuum problem. donidavis Eclipse Problem Diagnosis 27 08-29-2010 09:07 PM
88 Lebaron Turbo - no power to fuel pump 1988lebaronturbo Lebaron 3 05-02-2009 03:30 AM
91 Lincoln TownCar Signature Series - No power 91lincoln Town Car 7 04-22-2009 11:46 AM
Tags
fuel , help! , pump , relays
