Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 02-23-2009, 06:53 PM
1988lebaronturbo 1988lebaronturbo is offline
88 Lebaron Turbo - no power to fuel pump
88 Chrysler Lebaron 2.2L Turbo, J-body convertible
I did not start the Lebaron for about 3 months because the battery was dead. I replaced the battery and it would not start. When I sprayed starting fluid in the intake it started until the starting fluid burned out. So, it has fire. But, it isn't getting fuel. Also, the fuel gauge doesn't indicate the fuel level correctly. The tank is full, but the fuel gauge indicates the tank is empty, or at one bar (electronic cluster).
I then checked the fuel pump connector at the tank end, as well as the fuel gauge sending unit connector at the tank. With the key in the RUN position, I used a light volt tester at the fuel pump. No power to the fuel pump connector. At the tank, the fuel sending unit connector indicates there is power (the tester light was on, but dim).
I then tested the ASD relay (Automatic Shutdown) on the left side of engine compartment. The ASD connector is getting power. If the engine is getting spark, then the ASD is working, right? The ASD wouldn't just work for the spark, and not for the fuel, right?
I don't know if the fuel pump has some inline fuse. Is there such a fuse? I don't know where else to test the fuel pump wiring to see where the problem is.
Could it be that the engine needs to be cranked over in order to show voltage at the fuel pump connector at the tank?
Any help is greatly appreciated. Thank you.
Old 03-03-2009, 08:44 PM
madmanmapper's Avatar
madmanmapper madmanmapper is offline
Re: 88 Lebaron Turbo - no power to fuel pump
Hmm I'm not very sure about this. But hook up your voltmeter to the fuel pump plug. You might need a friend to help you with this. With the ignition key off, read the volts, should be zero. Have your friend turn on the ignition key while you are still reading the voltage across the fuel pump plug. See if it gets any power when you turn the key on.
Old 04-07-2009, 03:37 PM
microedit microedit is offline
ASD relay is a pain in the neck. When you first turn the key to the car on without cranking it you should hear the fuel pump turn on for a couple of seconds. If it does then you don't have a problem with fuel pump. Could be the fuel injectors. The fuel pump works by engine vacuum so other than electrical connection to it you also gotta have a good vacuum, this is the third tube that comes from the tank near the top of the engine passenger side. To test listen hear if pump comes on when turning on car without cranking the only other noise is the relays should click on at the same time. Let me know cause this information will affect resolving the diagnoistics of the problem. Adam at [email protected]
Old 05-02-2009, 03:30 AM
Crazy idea: check the continuity of the wires going to the pump. Since you say it receives no power.
Tags
1988 , chrysler , fuel , lebaron , pump
