Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 03-23-2009, 12:00 PM
91lincoln 91lincoln is offline
Send a message via MSN to 91lincoln
Unhappy 91 Lincoln TownCar Signature Series - No power
Hello,
I have a 1991 Lincoln TownCar Signature Series , it recently stoped working all together and I think I know what caused it , but not sure what to do or check.
Recent events: I installed a Kenwood deck , worked fine for a few days , I turn the corner to pull into my driveway and start hearing my acceleration through the speakers. The engine rev and noise was in sync with the noise coming from the speakers.
Once I put the car in park it lost complete power. I can't even get an ounce of power from a jump , no lights etc.
What could be the cause of no power? I thought about it being the battery , but from the neighbor giving me a jump the car should have gotten some sort of power from his battery at least.
If you need more information to help come up with a solution , just ask me and I can reply asap.
Thanks in advance for any helpful comments.
Old 03-23-2009, 08:12 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: 91 Lincoln TownCar Signature Series - No power
Check your bat connections.
Mike aka JYD
Old 03-24-2009, 11:20 AM
Battery cables , connections etc are all fine. I've looked at the fuses , according to the guy at autozone if the fuse is blown or bad the wire in the middle would be broken. They all looked fine to me.
Next thing I can think of is having the battery tested
Old 03-24-2009, 03:08 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
Have the battery checked, and the fuse able links.
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 03-25-2009, 04:21 PM
Bearfoot Bearfoot is offline
If a fuse is bad the wire does not have to be broken. That is a common fallacy. Use a continuity tester, if nothing else. Often a fuse will look good but won't be. The same applies to light bulbs. I just changed one in my light bar that looks good but won't light. Put in a new bulb and it lights right up.
Stan
'98 Lincoln Towncar - white 100k
'08 Mercury Grand Marquis - maroon 30k
'98 Dodge 3/4 ton, Cummins Diesel, 4 x 4, 4 door, extended cab, long bed. 140k
Old 04-21-2009, 08:39 PM
Thanks everyone , the problem was the Power Distribution Center was dead. Battery was fine as well as the fuses.
Old 04-22-2009, 06:05 AM
What was the problem with the power distribution center?
Mike aka JYD
Old 04-22-2009, 11:46 AM
The mechanic said the center wasn't getting any power to it. A wiring problem somewhere. Also the stalling out problem was a vacuum leak in manifold. All in all $300 to fix both , and then it came out with a new problem ( Gotta love it ) The AC and heat does not blow.
Tags
lincoln , no power , town car , won't start
