Old 03-30-2012, 10:21 PM
jamesmetairie jamesmetairie is offline
it,s back=- p-0440
a week ago it appeared right after i picked up the car from the tranny shop.
a friend erased it.
now today it,s back.
anyone ever had luck figuring p-0440?
gas cap and many other parts involved.i,m thinking maybe a vacuum hose got broken when tranny was rebuilt.
what happens if you give up and don,t ever fix it?
Old 03-31-2012, 07:38 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: it,s back=- p-0440
http://www.obd-codes.com/p0440
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 04-01-2012, 10:32 AM
Tech II Tech II is offline
Go back to the tranny shop and have them do a visual of the lines and connections and harnessess of the EVAP system.....
But did you check your cap, and the mating surface of the fill pipe?
Old 04-27-2012, 05:51 PM
jeffcoslacker,s post about the line to the purge solenoid valve solved my code p-0440.
1st i brought the car back to the tranny shop. no help there.
when i read jeffco,s post i got curious and grabbed the line above the brake fluid resevoir. sure enough it was not conected to anything. just by feeling around i found the connection spot and now all is well and the "ses" light went out by it,s self.
Old 05-03-2012, 07:16 PM
Although I didn't read the code, I had a similar problem after doing my LIM gasket....I failed to plug that line back into the valve and had the CEL lit and a strange sound from the firewall side at idle.
...empty gun rack.
93 PI CV - no electric then it comes back jabhawk Crown Victoria 1 10-10-2006 09:10 PM
My Driver Seat... Can I move it farther back?? jetguy35 MY 01-06 1 09-03-2005 07:10 PM
Putting it all back together V T E C H Integra 15 04-01-2005 12:10 AM
Doing 70...engines cuts out...sometimes it catches back on... bj1255 Grand Cherokee | Grand Cherokee SRT8 6 10-20-2004 10:57 AM
