Old 03-30-2012, 09:42 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
99 s10 ecm issue
i have a 99 s10, 4.3 manual trans with 4x4. the issue i have is the abs and ses light is on. connected snapon mt2500 scanner, i can read abs fine. as soon as i ask it to read data or codes from ecm it blanks out and restarts. i even completely unplugged the ecm, same thing. any ideas? any wires to check for shorts or grounded? basically the engine idles ok and light throttles ok but under heavy load or acceleration it missis but no blinking ses. so i need to read the codes. i tried using the scanner on another truck and it read ecm fine.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 03-31-2012, 09:25 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 99 s10 ecm issue
Are you using obd 11 or engine vin setup on scanner?
Can you run by AZ and see if there scanner will read the engine codes?
MT
Old 03-31-2012, 06:09 PM
it will let me enter vin fine. then i get to the main screen to select to read codes or data. when i select anything it restarts.
Old 03-31-2012, 06:56 PM
MT-2500's Avatar
AF - Advisor
Try for OBD11 codes.
Let us know how that goes .
MT
Old 03-31-2012, 07:54 PM
it read the codes on obd2 mode so i dont know why it wont otherwise. it came up with o2 sensor bnk 1 sensor 1 no activity. found it unpluged. truck still runs bad no ses yet. the only thing ive noticed is that bank 1 sensor 3 doesnt seem to be working. do you know where that might be?
Old 04-01-2012, 09:13 AM
MT-2500's Avatar
AF - Advisor
Did you clear codes and drive it?
Does bank 1 and bank 2 sensors work now and read the same/even?
Did you drive several miles and get it to go to closed loop?
If senor 3 not working check wiring plugin and switch or replce that sensor and check for working.
I would also go by your auto parts place and get them to check it with there computer tester.
MT
Old 04-01-2012, 08:32 PM
well i told scanner that truck was a 98 and it works fine now. i did how ever find that both o2 sensors were stuck reading lean. changed them out and alot better. now need new u joints. driven several times and no ses so it should be good. still seems to be lacking power past 3000 rpm. by the way its a 5 speed.
96 S10 Ignition/Starting Issue fmhsgrad96 Problem Diagnosis 5 05-25-2012 08:19 PM
98 S10 ECM I fuse blowing harryevan Problem Diagnosis 7 10-10-2009 12:53 PM
1987 s10 ecm problem jonny.chinn Problem Diagnosis 3 02-16-2007 05:24 PM
'94 BZR- S10 ECM B- Fuse keeps blowing??? Shawn Herrity Blazer 1 03-27-2005 08:40 AM
S10 ECM RESET/HO2S Problem/Rant garrelt1 S-10 1 01-25-2004 09:49 AM
